Question about RCA HD52W59 HDTV Projection Television
Error code 1 9 turns on then hums when it turns off immediatly after
  • RCA Master
  • 8,617 Answers
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com
Posted on Aug 20, 2010
I have a brand new 1 1/2 hp superflo. I wired it in and turned on the power, it hummed for a few secounds and trip the breaker. now it it wont work and just immediatly trips the breaker. Any ideas as
It sounds like the motor shaft is stuck. The back end of the motor has an end cap that comes off so you can access the end of the motor shaft. Try this with the power off; Remove the cap (center rear of the motor),Using an open ended 9/16 wrench you should be able to turn the shaft back and forth. A motor that has sat for a while will sometimes act like yours did. A nudge with the wrench usually breaks it free. Remove your wrench and turn pump on. If it still won't start the motor may be defective.
Dec 28, 2012 | Pentair Superflo 1 1/2 Hp In Ground Pool...
Dryer hums and heats when plugged in
What is the complete model number of your unit?
Dec 02, 2012 | Dryers
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
When i turn tv on it immediatly shuts back off
If model number begins with WS or VS (on back of set) when it shuts off press and hold both the menu and input buttons for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know model number and what error code you find.
If this was helpful, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 17, 2010 | Mitsubishi Televison & Video
Xerox XC1020 Flashes code H 4
This should resolve your issue. If not it would most likely need a heat rod. But there ia probably a 99 percent chance this will cure it. Let me know please.
Performing a Fault Reset 14 will reset your copier and will help to clear error codes.
  1. Turn the power off.
  2. Locate the Clear Button, which is grey in color, in the upper right corner above the green Start Button.
  3. Locate the Auto Button the lower left corner of the Control Panel.
  4. Turn the power back on.
  5. Press the buttons in the following sequence, releasing each button after each time you press it: [Clear], [Auto], [Clear], [Auto]. Every light on the Control Panel should go out, and the error code should clear.
  6. If the error code has not cleared, wait a few seconds then repeat Steps 1 through 5.
  7. Program the copier as if you were going to make 14 copies.
  8. Press the green [Start] button to store the reset code. The copier will return to the ready position.
  9. Run a test copy.
Feb 16, 2009 | Xerox Office Equipment & Supplies
My Intertherm, electric ignition furnace will hum and hum but not click on. There are two yello flashing lights until we reset it by turning off the gas and turning down the thermostat. The unit resets...
That blinking yellow light is an error code. If you look behind the main cover there will be a wiring diagram and error code chart. This will give you an idea what the problem is.
Nov 07, 2008 | Heating & Cooling
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
RCA HD52W59 HDTV Projection Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
