Question about Dell 922 All-In-One InkJet Printer
Dell 922 all in one paper jam
There was a paper jam, I pulled the paper out, and it still says that there is a paper jam.
  • Anonymous May 10, 2008
    Our problem with the printer is that it wont feed the paper down properly when printing.
    We have to manually push the paper down part way until it starts feeding
    thru.
    What can we do?
    Genius:
  • 3,587 Answers
Maybe following this list of suggestions might be of some assistance?
Posted on May 03, 2008
My Dell 922 printer will not grab the paper anymore. The rollers are turning but nothing is happening,
The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 29, 2011 | Dell 922 All-In-One InkJet Printer
Dell 922 saying there is a paper jam
First try this. Turn off the printer, remove all the cartridges, drum, open all the doors and remove all the trays. Now verify that there's no actual paper jam by exploring through the inside of the printer. You can use a blower to blow any dust or pieces of paper, etc.. from the printer. Now use the manual feed and put in thicker paper several times (push in and pull out). Again reinstall and reconnect every components and boot the printer. If the actual printer's paper sensor isn't broken or stuck or twisted, this will definitely clear the paper jam message on the printer.
If the problem persists, please download this small text file and follow the instructions (click here). Open the link, click "Download Now" button, wait for 20 seconds and again click "Download File Now" link and read the instructions and follow step by step.
Good luck.
Thanks for using FixYa.
Jul 16, 2010 | Dell 922 All-In-One InkJet Printer
Paper runs through when switching on - no jam
Hi there
I not think that there no-way out here, you will have to get it fixed this belt it for the inks to be pulled on so you will see this error all the time, like it is a paper jam.
All the best Pineworks
Apr 28, 2010 | Dell 922 All-In-One InkJet Printer
My dell 922 printer say there is a paper jam but there is no paper stuck in the machine
check the full inside of the machine, even a small piece of paper in some of the spooler inside can cause the printer to malfunction.
Dec 07, 2009 | Dell 922 All-In-One InkJet Printer
Paper feed problem with Dell 922
Take a cotton swab and some alcohol and clean the rollers. They may be filled with paper fibers.
May 03, 2009 | Dell 922 All-In-One InkJet Printer
Paper will not feed correctly,,,it pulls off center and then jams
You have something jammed in the paper path of the printer. Un plug it, remove the paper, and turn it upside down. Something will probably fall out. If not, shine a flash light down inside and look. It's most likely a paper clip or something. This is a common problem with those type of feed systems.
Apr 15, 2009 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One Printer will not print anything
The printer does not feed paper from the tray and then states that there is a paper jam. I have removed all paper and there isn't a paper jam. It will feed paper through the lower roller and straight into the printed paper tray, but will not feed a new sheet.
Nov 01, 2008 | Dell 922 All-In-One InkJet Printer
Problems with Dell 922 All-In-One InkJet Printer
check to see if the ink cartridges are installed properly, or if there is a paper jam. If not unplug it for 2-3 minutes, and try using it again.
Jan 09, 2008 | Dell 922 All-In-One InkJet Printer
Paper Jam
you may have broken the paper sensor lever or all of the paper isnt out
Nov 07, 2007 | Dell 922 All-In-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
85 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
