Question about Photography
How do I remove the film door on my Nikon N90
Nikon sent film door replacement you know for the stickly problem free of charge.There were no instructions so, I only see one screw on hinge when door is open. I removed the screw and saw no way to remove door. So whats the trick I'm missing? Hope you can help Thanks for the time.
  • 667 Answers
You should not have removed the screw. It sticks out for a reason. You push it down to release the top hinge of the door.
Posted on May 07, 2008
Dear Hogn8,
When you say "for the stickly problem" what do you mean? The "sticky" problem, perhaps? Please explain.
The film door on my Nikon N90 has begun deterioating (melting) and I wonder if that's why Nikon replaced your film door for you.
Best, wallah
Posted on Jul 23, 2008
Want a new rear film door for a F90X
http://uscamera.com/1b999-517.htm
That's for the back cover for the Nikon N90/N90S, which is what the F90/F90X are known as in North America.
Sep 28, 2010 | Nikon Cameras
Nikon f100 film won't advance
We will assume you know how to load the film to the red mark. If the film is not advancing a couple of things could be happening. When you close the back door it is not engaging the film to hold it against the take-up spool. If so then that needs to be fixed. The other thing to check is the left side where the film cartridge goes in, does it turn. If not it is binding the film cartridge. Nikon Film 1-800-645-6687
Apr 19, 2010 | Nikon F100 35mm SLR Camera
Film door latch broken
Nikon doesn't supply the film door any more. You can buy a repair kit from USCamera.com to replace the latch on the film door
Jan 02, 2010 | Nikon N6006 35mm SLR Camera
Camera film door will not latch. The door latch
Can it be repaired? It needs a new latch piece. Maybe a new door, if its all one piece.
I do not own one so not sure about that model. Look at the door hinge. If a small lever sticks out of the hinge, it may be easily removed and replaced with a new door. otherwise you need to remove the bottom plate of the camera to replace the door. Be very careful doing so as things could pop out when you open it.
You could also send it in to a repair shop, where they will also clean, lubricate and adjust it before returning.
Is it worth it? Only you can answer that. You might be able to pickup a used one on Ebay, so you have a source of parts.
If you have no reason to keep that particular camera, replace it with a newer Nikon, so you can keep using your flash and lenses.
Oct 04, 2009 | Nikon N6006 35mm SLR Camera
Looking to download N90 nikon film slr manual
http://www.butkus.org/chinon/nikon.htm
Sep 26, 2009 | Nikon Photography
N90s -How do you attach the Film Pressure Plate to the film door?
Press down and slide one way or the other. It's generally held by two pins that slide into hole slots and lock in place
Jul 11, 2017 | Nikon N90S 35mm SLR Camera
Lens Error on Nikon Coolpix L3
Sometimes removing the batteries for a day may correct the problem temporarily. But the real problem is really in the lens mechanism. "Lens error"can only be repaired by Nikon or an authorized repairman. I sent mine back in Dec. 2007. It was repaired free of free of charge under the warranty. It was fixed and returned very fast.
The same problem just reoccurred and I sent it back to Nikon this very morning. They told me this is not a problem with this model, but I beg to differ. My internet search revealed that this apparently is a problem with many Nikon lens mechanisms.
Sep 21, 2008 | Nikon COOLPIX L18 Digital Camera
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
Jul 26, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
How to remove the film door on Nikon N90
Along the hinge side near the top, a small screw sticks out from the plastic end of the film door. (opened). Push the screw down with your finger to release on edge of the door and lift it free of the camera
May 03, 2008 | Cameras
Nikon N65 Film Camera Broken latch
You have to replace the whole door. There is one on eBay, but you won't like the price. Find it here: eBay
Mar 15, 2008 | Nikon N65 35mm SLR Camera
Photography Logo
311 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
