Question about Panasonic Electronics - Others
My Panasonic inverter indicates a failure H23 What does that mean ?
What does H98 in the display mean?
If it's a Panasonic inverter, it probably indicates a problem on the inverter board.
Oct 29, 2016 | In Microwave Ovens
Panasonic NN 9853 Microwave. Won't cook on Microwave but shows H97 in screen. What does this mean?
The code probably indicates a problem with the inverter board. The board can be tested, but the test procedure requires some knowledge of electronics.
Go here for instructions:
http://educypedia.karadimov.info/library/Inverter.pdf
Oct 21, 2016 | Panasonic Microwave Ovens
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Why won't my panasonic inverter microwave will not turn on?
check when the fuse is blown,means inverter unit is faulty
Aug 05, 2014 | Panasonic NN-S251 Microwave Oven
H23 fault code
Diagnosis display = H23
Abnormality / Protection control = Indoor heat exchanger temperature sensor abnormality
Abnormality Judgement =
Emergency operation = O (Cooling only}
Primary location to verify = • Heat exchanger temperature sensor (detective or disconnected)
This is from the following link:
http://errorcodeairconditioning.blogspot.com/2010/10/panasonic-error-code.html
May 05, 2012 | Panasonic Heating & Cooling
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Whirpool error h23
h23 is a fault code , refer to your machine handbook for explanation of these codes.
Nov 09, 2009 | Washing Machines
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Turns off after 3 sec
Usually this indicates failure of the magnetron and/or the inverter. Neither is easy to test without specialised HV equipment. Often the cause is operating the oven without anything in it. If this has happened, it will generally be failure of the magnetron.
Replacement of the magnetron is relatively easy (about 15 minutes) and the inverter a little longer but if you do not have the knowledge/skills please do not do it - there are very dangerous (deadly) voltages associated with magnetrons even after they have been switched off.
Cost of magnetrons ranges upwards from USD25 to USD100 (from Panasonic spare parts) and inverters range upwards from USD125. The cost of parts is often the reason microwave ovens are not repaired.
Doug
Nov 05, 2008 | Panasonic NN-T990SA Microwave Oven
My microwave shows a H98 error code . Does anyone know what that means ?
That would be a Panasonic inverter failure code, but please reply back with your brand and full model number.
May 05, 2008 | Microwave Ovens
Electronics - Others Logo
93 people viewed this question
Top Panasonic Electronics - Others Experts
 Grubhead
Grubhead
Tom Chichester
Are you a Panasonic Electronics - Other Expert? Answer questions, earn points and help others
