Question about Cartier Watches
I need a new crown for my sterling silver must de cartier ladies watch
  • 40 Answers
Cartier are known for not letting the spare parts become available .A generic crown can be fitted by a good watchmaker so it will work fine and look ok but wont be original.To get the original parts you will need to use a Cartier stockist.
For further advice use www.rolexrepairs.co.uk
Regards
Posted on Aug 21, 2010
How do I wind a Cartier ballon blue watch ?
more than likely it has a screw down crown. Turn the crown towards you to release it from the case tube then wind it forward. Make sure that you tighten the crown when finished winding it or you will get water into the watch.
hope this helps, gabe.
Oct 22, 2014 | Cartier NEW CARTIER BALLON BLEU LADIES...
Serial 17050343
The serial number on that watch indicates that is 100% a fake/counterfeit.
Jul 25, 2013 | Cartier W20012C4 Watch Santos Ladies -...
I need to change the date on my Cartier Roadster (back 2 days). How do I do that?
Thank you for contacting FixYa.
  • Pull the crown of the analog/date Cartier watch and rotate it clockwise or counterclockwise until you see the date advance in the display window at about 1 a.m.
  • 2 Use the quick date set method by rotating the crown counterclockwise after reaching 1 a.m. until the hands reach 7:30 p.m. Then again rotate the crown clockwise back to 1 a.m. Repeat the procedure until the correct date is displayed.
  • 3 Adjust the date forward or backward 12 hours if your Cartier watch changes the date at the noon hour.
  • Best regards. Jewel
  • Sep 13, 2010 | Cartier Roadster W62016V3 Wrist Watch
    Hi - I have a ladies Cartier Santos watch and am told I need a new movement (Quartz)can anyone tell me where to get one and rough price? Kindest regards David
    The only place where you are likely to get a price from is either an authorized dealer or Cartier.
    I suggest that you go to "Cartier.com", select your region and then "timepieces".
    At the bottom of the page you have a choice of store finder or service etc.
    Feb 21, 2010 | Cartier Santos W20011C4 Wrist Watch
    Did/does Cartier make tank watches that are gold plated over sterling silver?
    ARMANI does NOT DO that. Plating is applied to stainless steel only. Rate me, plz.
    Feb 04, 2010 | Watches
    Missing blue winder where can I buy it?
    If that is a real Cartier watch and you have lost the crown which is the piece that you use to either wind or set the time then you will need to send it back to Cartier. They dont sell parts to watch repair shops! :-)
    If it's a replica then you can take it to a reputable watch repair shop and they can install a generic crown!
    http://www.cartier.us/#/contact-us/call-an-advisor
    Jan 19, 2010 | Cartier 21 W10072R6 Wrist Watch
    Setting time and date on my Cartier Pasha watch.
    Do not be so afraid. Unscrew that big crown fully, pull off and then you will see the real setting crown(quite small one), called an underlayed crown.
    That little chain is hard enough to withstand your pulls, unless you are drunk. :)))
    When you get that small crown handy- you can set the time and all the features.
    If the small crown is not moving, your watch is rusty and you will need a proper watchmakers help.
    Don't forget to rate, please.
    Jan 11, 2009 | Cartier Pasha 32MM WJ111156 Wrist Watch
    How to set time on cartier chronoflex?
    to set the time and date of cartier watch , full the crown at half setting possition then wind it until the date move push the crown to the normal possition then full the crown twoo times to time setting possition then wind it again until you search the correct time,fush the crown to the normal possition after setting,
    Aug 24, 2008 | Cartier Watches
    Fake or not
    Generally you have to open the watch to see the movement but a lot of fakes are plain workmanship flaws.
    A real Cartier will not be made from base metal. It will be made from stainless steel or precious metal.
    A real Cartier will most likely be built with screws in the band instead of cotter pins.
    When you pull the crown to set there will be no play in the set lever. In other words when you spin it, it will begin to turn the hand immediately and there will be a slight resistance. It will not feel loose.
    As stated, the best way to tell is to look at the movement. Cartier uses a high grade Swiss movement most likely marked ETA.
    Oct 13, 2007 | Timex E Tide Temperature Compass Watch...
    Watches Logo
    235 people viewed this question
    Top Cartier Watches Experts
    Jimmy Accardi
    ray gallant
    Are you a Cartier Watch Expert? Answer questions, earn points and help others
