Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Lexcion lamda and a mixer
Can you connect a mixer to your lambda and if so how can you go about doing that ?
  • 4 Answers
Yes you can. simply take a 1/4 in cable from the main out of you mixer and plug it in through one of the line in inputs on the back.
then plug whatever you want to record in through the mixer
Posted on Jul 11, 2008
if the cat is a stand alone cat with no downstream lamda sensor then all that wil happen is the emissions will be high if in the uk that would fail the mot test 1 having no cat fitted if that model/year should have plus out of spec emissions if its got a downstream lambda and removed/disconnected will display a engine warning and put the engine control module into default
Mar 21, 2017 | Mazda Cars & Trucks
How do I solve on range rover vogue which is reading ,lamda control adaption exceeds lower limit bank 1&2.last occurrence-plausibility
I don't have a lot of experience diagnosing such faults. I think live data would be more useful than just fault codes which tend to send the inexperienced down false trails.
Lambda responses are only reliable when the other engine components are working optimally. If an injector is dribbling a little for instance, a fair percentage of that fuel will cause the lambda to react to a rich mixture and the management will shorten the injector pulses effectively making the engine run weak.
I suggest you check the precise function of the light that illuminates as some vehicles have more than one light for check engine and emission purposes.
I would also suggest you follow best practice and ensure the maintenance is up to date and competently carried out before proceeding further and carry out a thorough visual inspection of pipes. wires and cables and connections in the engine compartment.
An experienced eye using a good scanner to view live data will be the best way to a successful diagnosis.
Jun 07, 2016 | Rover Cars & Trucks
Engine light is on and car is shaking
Unless you take it to a shop to diagnose it, I would guess that it is due time to replace lambda sond,
The lamda sond is normally located a little down the exhaust manifold, maybe covered by a shield.
Good luck.
May 16, 2011 | 2003 Chrysler Town & Country
Replacing lamda sensor
whats tht lamda sensor, anywhere anyplace place you can do it if you have the tools and you think you can do it, obsereve the traffic rules and regulation,
Jun 19, 2010 | 2005 Kia Sephia
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Jul 14, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
I have a 1997 Jaguar XJ6 Very high emmissions?
I have an X300 and had very high emmissions at an MOT. Diagnosed by Jaguar as the Lamda (02) sensors. Bought alternatives as Jag wanted a fortune and had them fitted by the Jaguar Main Dealer. Took it for MOT and it still had the same emmissions! MOT chap swapped the leads of the two Lambda sensors over and it was perfect! Still don't know if was the problem or the sensors were faulty.
So check if either the Lamda sensors are faulty or they are plugged in the wrong way. Try swapping the leads first as it is much cheaper!
Aug 13, 2008 | 1995 Jaguar XJ6
Lambda Sensor or Air Mass Meter?
replace the temp sensor in the thermostat housing behind alt(2 wires)
Aug 08, 2008 | 1999 Volvo V70
Cubase software lexicon Lambda and IMAC
Hey robert I can help. What model Imac do you have and Lexicon do you have?? Please let me know.
Feb 10, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
221 people viewed this question
Top Lexicon Computers & Internet Experts
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
