Question about Whirlpool Duet GHW9150P Front Load Washer
Washer does not complete a cycle. Error message E-07 pops up. drainage?
  • Whirlpool Master
  • 12,061 Answers
Https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
service and repair manual above use this service and repair manual to isolate and remedy your problem.
If you do not wish to DIY, please contact a Whirlpool service center and call them out, then ask for a "Quote" before allowing any work to proceed. . Motor Control Unit Error
The Central Control Unit has detected a short in the motor control unit. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the MCU
  • Check the Drive Motor
  • Check the Wire Harness
Posted on Aug 20, 2010
I keeping getting a F 02 error or a sud error
"F02" is a Long Drain error code. This is an indication that there's an obstruction somewhere in the drainage system. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the lower toe panel directly below the door in the FRONT of the washer. They are located under the bottom front edge of the panel. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: The washer will not complete a wash cycle as long as there is an error code present. Once the problem has been corrected, the washer should run normally. The "SUD" error commonly occurs in conjunction with a drainage problem due to air (sudsing) being detected in the drain pump. Fix your drainage issues and the "SUDS" error should go away.
Feb 24, 2010 | Kenmore Washing Machines
F02 CODE CONTINUE TO POP UP AND CYCLE STOPS
repairclinic.com
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an F20 error message or SUD. I have
http://www.wikihow.com/Fix-a-Whirlpool-Duet-Washer-F-20-Problem
Jan 22, 2010 | Whirlpool GHW9300 Duet Washer
The washer machine get stopping and getting error message saying F-21
"F21" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases, this means you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
You may have something getting caught in the pump impeller and slowing it down. Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The washer will not complete the cycle with an error code present. If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can commonly occur with the F21 error code as this is can be generated when air is sensed in the drainage system.
NOTE: If replacing the drain pump is required, the following link explains how:
If you have any questions about this repair, please let me know. I hope this helps you.
Dec 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Showed F02. Doesn't spin in the spin cycle, just
"F02" is a Long Drain error code. This is an indication that you have an obstruction somewhere in the drainage system. In most cases this means there is a clog in the drain pump. If the drain system is clogged or restricted, once the error code is generated, the washer will not complete a cycle until the error is resolved. The following link explains:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris and small articles of clothing can commonly clog in this area as well causing the drain cycle to fail.
NOTE: The "SUD" error code can often occur in conjunction with the "F02" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Nov 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Asko washer 20004 stopped mid cycle, water is
Do not play with water and 240volts or 120 volts....it is a LETHAL cocktail.
Get a techo to save you the headache and possibly YOUR LIFE!
Oct 19, 2009 | Washing Machines
Washer will not drain or stat new cycle, no error message
What is the make, mode # of your washer? Do you have dial or, a keyboardl controls
Apr 26, 2009 | Whirlpool Washing Machines
HI, this is a defective CCU(Central Control Unit). you must have it replaced asap. this will correct the error.
Apr 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bad drainage but no error message
there are 3 screws (probably torx bits) at the bottom panel on washer. remove this panel and then you will notice the front of the pump unscrews. lay a towel down and unscrew front of pump andremove debris from debris basket
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
F H code during cycle, will not complete cycle
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more involved error codes to try to resolve, because it can have various causes. The first thing to try before troubleshooting is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches. If the error code reappears, I suggest you begin with the easy items that you can eliminate first. Double check your fill hoses and water source, followed by verifying your drainage to ensure you don't have a siphoning problem and checking your drain pump for clogs.
If you still have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
82 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
