Question about Samsung Cameras
Digital camara opening of lence not working,as you switch on cover come out and immediately closed.
    Sergeant:
  • 192 Answers
Maybe it is low battery in the system..
Posted on Aug 20, 2010
Switch on camara, lens opens then closes leaving lens error ! on screen. them camara switches off ??
The systems control board has detected a malfunction in the lens "probably the ccd circuitry" in the lens housing and should be checked out by a camera technician, but you will find it is more than likely not cost effective to repair.
Jan 31, 2011 | Nikon Coolpix S3000 Digital Camera
Nikon lence is not going inside , It showing lence error
ya even I hav d same problem..!! I dnt think its covered under warranty..u will have to pay d service charge.
Apurva ,Lucknow
Apr 28, 2010 | Nikon Coolpix S210 Digital Camera
Needs help
hi,if your leance could not open when you turn on camera so may be you must cheak the lence assembly breckeg , if the lence is open then servise lence unit and fix it properly,and the easy way is remove the lence unit and first remove moter from it and rolling well as possible.it must be smoth rolling between beralls of lence,then roll the moter alone well by using adapter about 5 volts,now fix it by aqurat ,you find a magic
Aug 25, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lance alignment is disturbed
hi,if you are a tecnition then open yor camera and remove the lence assembly,then remove the motor and clean the lence unit properly ,and check that smothness between lence beralls, it must be rolling smothly ,and roll the moter by using adapter of 5 volts ,roll motor both side ,after that fix it properly ,now you can check it by put suply on motor and see what has be done,if lence responce smothly in and out then fix it with camera,and see the magic
Aug 25, 2009 | Nikon COOLPIX L10 Digital Camera
Camera will not switch off when lens cover is closed
This happens because the camara already belives it is off. This is a problem i have had with my vivitar camara as well.
Jan 14, 2009 | Vivitar Vivicam 5105s Digital Camera
TURN ON AND OFF
there is something in ur camara under the cage broken, very small pice, open it & take it out & close it again & it will work.
Dec 27, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera lense wont close
I had a problem this week when i tried to close my camera and the lence would not close but the camers would
I took the batterys out, then a couple of days later when i replaced the batteries and switched the camera on the lence closed properly, so i guess my solution was to remove the batteries and see what happens it did the trick.
Maria
Jun 22, 2008 | Kodak Cameras
I need to delete the internal memory on my camera
There are two ways to reset the camera:
1. Leave it without battery for 24 hours
2. Follow this procedure:
a. open the card door and set the camera to "P" mode
b. switch on the camera
c. the "card cover open" screen will appear
d. immediately press both the OK and the monitor button (below) and
keep them pressed for a few seconds until the "Camera/SDK setup" appears
e. Now you can reset the camera by choosing "Camera" and navigating
through.
Jun 05, 2008 | Cameras
Shutter problem with a sony dsc-w30 camara
Make sure the battery is strong and not failing you and that the extending lens cover parts are clean. You may have gotten something in there.
Dec 24, 2007 | Sony Cyber-shot DSC-W30 Digital Camera
I pressed in a pop up lence manually...
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 22, 2006 | Konica Minolta DiMAGE G500 Digital Camera
Cameras Logo
22 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
