Question about Bose Lifestyle 20 System
No light or sound by use of manual switch or remote unit!
    Sergeant:
  • 192 Answers
Try to check the connections of it.. be careful of the polarity of wires and it's color code.. tell me what are the colors and i guide where to place it..
Posted on Aug 20, 2010
Ac going to both indoor and outdoor units. Compressor unit runs if relay pressed manually. Indoor unit does not have any lights on and does not respond to the remote or test/emergency switch..
Sounds like compressor contactor won't pull in due to the low pressure switch. You have to find where you're losing voltage. Unfortunately sounds like a refrigerant. Voltage not making it all the way to contactor. Low voltage not high voltage
Jun 07, 2016 | Heating & Cooling
Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
sounds like the radio signal amp is blown..that is a full replacement deal..that would explain this, and the power
#glitch could certainly cause this problem..
Oct 26, 2008 | Hampton Bay 52 In. White Redington...
. Can I buy a switch unit that plugs in where the unit for remote is and has chain pulls and light ?
I am not sure we can follow. Please set some context like
Remote of what equipment ? TV / Heater / DVD / STB / Lights ?
Perhaps you can reword your question for us to contribute
May 29, 2016 | Televison & Video
Model DR-S2.0. Why doesn't it respond to remotes?
If your receiver does not respond to the original remote, the remote may have failed.
If your receiver does not respond to your Harmony remote, the remote may not have been programmed or may have "forgotten" what to do.
Another possibility is that the infrared receiver has failed
Feb 16, 2016 | Onkyo Audio Players & Recorders
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
The unit has a green, yellow and red light (all in a line) blinking. The ac does not respond to any of the controls on the remote. Switching the unit off and then on again doesn't solve the problem.
This sounds like a newer unit with a large circuit board outside at the compressor unit. If so, it is possible that you only need to replace a fuse on that board. have you looked at your operators manual? There should be instructions on what those lights mean...
Sep 10, 2010 | Heating & Cooling
Wont open when I press door opener. makes a clicking sound and reset light is blinking
I, PRESS THE REMOTE THEN UNIT START TO BLINK THE LIGHT. ALSO IT WORK WHEN HOLD THE MANUAL SWITCH TO CLOSE AND OPEN THE GARRAGE DOOR.
Oct 27, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Genie excelerator/
Check to see if the Vacation switch is locked on your wall console. It is a switch on the top of the black wall button. If that is not the problem it sounds like you need to program your remotes. Drop down the plastic cover towards the back of the unit There is a learn button push that and a red LED will come start flashing press and hold the button on your remote until the LED stops flashing (solid red) press the button on your remote again and the light will go off. This will program a remote
Here is a copy of your manual
www.geniecompany.com/docs/GENIE%20EXCELERATOR-ENG.pdf
Oct 12, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Bose Lifestyle 20 System Logo
354 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
