Question about Whirlpool AWM8143 Front Load Washer
I have F12 showing on the panel, the machine wont work, ive checked for loose wires around the power to water tempurature area but everything seems ok there. help please
  • scoobydog10 Aug 20, 2010
    the model number is WFS1273BD, not the one stated above. thanks
    thanks for your help, ive followed these steps and cleaned hoses etc. the pump works fine because it drained water from drum when i filled it. but still cant do a full wash, keeps saying f12. hmmmm
  • Whirlpool Master
  • 19,396 Answers
Have a look at the heating element. On most Whirlpool built machines F12 means that the control board does not detect heat from element. Check element reading impedance. If impedance reads infinity, then the heater group is gone.
Posted on Aug 20, 2010
  • Whirlpool Master
  • 12,061 Answers
His problem is usually caused by what we professional servicemen call, "Frillies in the drain pump." 'Course, that's just generic talk for something that isn't supposed to be there. What you need to do is below.
- Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
Below is your service and repair manual.
http://www.eserviceinfo.com/downloadsm/17628/Whirlpool_AWM8143.html
Another link below showing parts diagrams etc.
http://whirlpoolwasherparts.estanciacatariri.bolivia.hardomonia.com/whirlpoolwasherpartsdiagram/
My front load washing machine is working but the water don't seem to enter.
First of all check filters in hoses & water valves, if ok then water inlet valve may be burnt out. Unplug power cord, remove top panel panel, check where 2 wires go to each water valve & check that area on valves for burning. If burnt or smells of burning, replace valve. IN SOME INSTANCES A COMPONENT BURN OUT CAN CAUSE DAMAGE TO CONTROL BOARD.
Apr 28, 2015 | Electrolux EW1000i Front Load Washer
Water will not come into the washer but moter is running.I have checked all hoses
shut taps and disconnect hose and place in bucket then make sure water comes out of hose by slowly opening taps.
If ok check if the electric valves open by setting first cold then hot on temp button. if hot water only then cold valve is faulty. you should hear a click sound from valves usually situated under control panel. if not then unplug machine, remove control panel and measure resistance on electrical connections of cold and hot valves with ohm meter at around 15 ohm if they are marked 12 v
meaning they operate on 12 volts from the control panel computer.
if no ohm reading or in the mega ohms replace valve. you can swap the wires between cold and hot if cold valve is faulty and use the hot valve for cold wash only then you wont have hot water.
If both valves ohms around 15 ohm then plug in and measure voltage at valve when machine starts you should get 12 volts on valves.( be careful for mains high voltage from mains wire entering panel when measuring keep hands clear of mains voltage and any water from panel.
If no voltage may then be computer panel faulty. check connections from valve connectors to panel and connectors on panel may be loose if not check voltage on panel where wires connect to computer panel if no voltage then make sure the water level valve is not stuck in closed position that will tell the computer the machine is full of water. just remove one or two wires from the level control valve (the level valve is a round plastic valve about the size of a small cup and has wires and a thin plastic pipe connected to it )and start machine if water enters then replace level valve if not maybe its computer board fault, replace. (you can test level valve with ohm meter and blow into the place where the pipe is connected by removing pipe it should click and ohm meter should show around 0.2 ohms when blowing and high ohms when not blowing.) some click twice as they have two levels.
Sep 05, 2014 | Fisher Paykel EcoSmart GWL15
Hey there. Ive got a 98' jimmy 4.3L. In the rain or damp weather my engine light comes on with misfires. Once it is in gear it has a rough idle and when accelerating it is slow an takes alot of power to...
Some of these vehicles had issues with water getting under the hood through the seal at the cowl panel and getting into the back spark plug tubes, once the engine warms up and the water evaporates the engine will run fine. There is a replacement seal thatyou can purchase to solve this problem. Hope this helps.
May 11, 2014 | Cars & Trucks
Faulty UT2 control panel for boiler
What is the make and model of the boiler?
Nov 04, 2013 | Computers & Internet
My hotpoint wf840 is displaying f-12 and wont start. Whats wrong with it?
  • F12 - Communication error
  • A thing to do is reset machine to do this unplug for 5 mins and plug it back in if still does it then check the wires into the pcb board to see if wires have come loose or water is on it hope this helps
Jan 06, 2012 | Hotpoint Ultima WF860 Front Load Washer
I have an FDF780 dishwasher that wont spray water
Sounds like wash pump is weak or siezed.
Sep 28, 2009 | Dishwashers
Wont spin does everything else but spin
Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
Indesit widl 126 s washer/dryer wont drain
Ive fixed my problem by turning it on, and after it does the standard pumping part pull out the power plug. Then when you plug it in again it will completely drain and its all reset again.
Aug 28, 2008 | Washing Machines
Whirlpool AWM8143 Front Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
