Question about Kenmore Refrigerators
I have a Kenmore, side by side, with ice cubes-crushed-and water, color-black. My problem started with the refrigerator side not being very cold, now the freezer side is not freezing. The fan is blowing and there is ice on the back wall from the 2nd shelf down almost to the bottom. The model no.363.9552752 serial no. L635 16906. I got the numbers from the lower right hand side of the frig. HELP!
    President:
  • 1,891 Answers
You said a lot . the frost in the freezer back would let know that you have a defrost problem . no frost means no frost . so the heater or the terminator have failed . the unit needs to be defrosted of ice and the heater cked and if bad replaced and always replace the terminator . orthe cause is the a d c adapitive defrost control . ,, mm
Posted on Aug 20, 2010
Ice maker crushes even when it is in the cube
If you pull out your ice bucket and look on the bottom you will see a long brass colored rod. Now, if you look inside your freezer section. you will see the slot the rod enters each and every time you insert your ice maker bucket. In the down position (normal) it produces crushed ice, When you switch the lever in the front for ice cubes, there is a plunger that lifts the rod and produces the combination that only allows ice cubes to come out. I would first check the plunger behind the panel and see if it is free.If it is not free it can cause the ice to be crushed...
Jun 06, 2010 | LG LSC26905TT Side by Side Refrigerator
My ice maker crushes when it is suppose to be giving me cubes. The crushing unit is OK
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Cubed Ice selected, crushed ice comes out
ice maker works. water thru the door works. lock works. light works, alarm works.
when i try to get crushed, ice cubes or quick ice.
nothing happens
Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
GE refer will not dispense cubed ice
I have the same problem. My GE refridgerator won't dispense ice cubes.
May 01, 2009 | General Electric GSS22JET Side by Side...
Kenmore side by side will only produce crushed ice and not cubed
remove the ice bucket inside and clean any clogged ice from inside the dispenser.
Apr 29, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice dispenser only dispenses crushed ice
Check and make sure your switch is okay. Some have a switch that controls whether you want crushed or cubes. If it is defective replace it.
Oct 23, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
63 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
