Question about Toshiba TDP-S8 Multimedia Projector
Reset Procedures Can you tell me how to reset the unit? thank you
  • Cortesed May 31, 2008
    Power Surge in storm. BulbStarts and shuts down.
    Problem Solver:
How do you reset the toshiba, to get it off standby..
Posted on May 25, 2008
How to reset Admin password on Samsung SDR-C5300N Digitalvideo recorder
If you have forgotten your admin password on a Samsung Security DVR, most experts would suggest that you have to contact Samsung and/or send it back to Samsung to have the administrator password reset. While this is true in some cases, it is not always necessary.
Many Samsung Security DVRs have a built-in reset that will allow you to wipe the settings of the device and reset the configuration, including the administrator password. Note that if you perform one of these resets, all settings will be erased and you will have to setup the DVR again. So you should only do this as a last resort - but to reset an admin password, the last resort is the only option.
Reset Procedures for Samsung Security DVRs
There is more than one reset procedure for Samsung Security DVRs, depending on the series and model. But in total, this only amounts to a handful. Since one reset can apply to several different models, I'll provide the resets here so you can try them on yours - I won't associate any one reset with a single model because a complete list of which reset works with what model Security DVR simply doesn't exist. Some of these won't make sense based on the buttons available on your unit or your remote. In those cases, just skip that reset procedure.
If you can perform a reset (in other words, if the instructions match what you have available on your Samsung Security DVR and/or Samsung Security DVR Remote), try it, and let us know in the comments if it works and on what model. If you tell us which model Samsung Security DVR you have, along with your results of each reset procedure, we can compile a complete list of reset procedures by model so that it will be easier for those seeking this information in the future to reset their Samsung Security DVR. Also, if you have a reset that you have used and you know works, let us know and we will add it here. I will update the list of Samsung Security DVR resets/recoveries as I encounter them.
So if one of these doesn't work for you, you may want to check back occasionally. In fact, if you leave your model number in the comments and any specifics about your problem, I'll try to get that specific reset for you. For any of these comments, just use the comment section at the bottom of this page - it is checked regularly.
Samsung Security DVR Default Password
For nearly all Samsung Security DVRs, the default password is 4321. If it hasn't been changed since setup, then you can just use that to access the DVR. The default password is included in the reset procedures for completeness. If you have changed your password or access code for your Samsung Security DVR since it was setup, or if you changed it during the initial setup, use that password in place of the default password. The password will be the latest password that was set on the DVR. If no password has ever been set, then it will be the default.
Steps to Reset your Samsung Security DVR
Samsung Security DVR Reset Procedure #1
Reset the unit to factory by pressing both [MODE] and [PTZ] button for 5 seconds
Then enter the 4321.
Samsung Security DVR Reset Procedure #2
Reset the unit to factory by pressing both [MODE] and [CH2] button for 5 seconds
Samsung Security DVR Reset Procedure #3
This reset will work on Android based DVRs only. All steps are performed on the device itself.
Turn the device Off
Wait 2 minutes
Press and hold the following buttons
POWER,
HOME
VOLUME UP
The unit should power on. Once it does, you can release power.
Use the volume UP and Down buttons to select "Wipe/Factory Reset" from the recovery menu.
Activate the reset using the HOME button.
When the DVR goes through it's setup again, it will be at factory defaults. The password will be 4321.
Samsung Security DVR Reset Procedure #4
This reset will work on SDR models. It may also work on other models.
With just the cameras showing, press the following in quick succession using the remote:
Freeze
Alarm
Freeze
Alarm
Freeze
Menu
Enter
Make sure you press them quickly, one after the other. If it doesn't work the first time, try doing it several times. It can take many tries to get the timing right. If/when it works, you should get a screen that gives you the option to reset.
Samsung Security DVR Reset Procedure #5
This reset will work on SDR models where procedure #4 failed. It may also work on other models.
Press the DVR Button to place the system in DVR Mode
Press:
Freeze
View
Return
As with Procedure #4, you may need to press Freeze, View, and Return in in quick succession a few times to get it to work. The timing can be tricky.
Samsung Security Reset Procedure #6
Courtesy Sergio Ayala
To factory reset the SDR-B74301
Reboot the DVR
Once the DVR has rebooted, enter the following sequence on the remote:
UP, RIGHT, 5, 3, 3
You will be prompted to do a factory reset. Confirm
This has been confirmed by several people. Thank you, Sergio! If this works for you, please thank him in the comments below.
These reset procedures cover many Samsung Security DVRs, but not all.
CCTV Networking Technical Support
Oct 07, 2017 | Samsung Home Security
My Samsung dvr model SDR75300n can't not reset my passwood.
you need to do on the dvr .remolt settings you cant do needs to be done by the dvr
Jun 15, 2017 | Samsung Cameras
I am facing the service engine oil error and need to fix.
Without knowing the exact year make model of your vehicle...it is impossible to answer that question. All cars have different procedures, some require expensive scantools to reset, some press and hold a button for 10 seconds.
Your owners manual usually will have the information IF its a button style reset. Look under MAINTANENCE
Dec 22, 2014 | Cars & Trucks
Nissan Altima Trottle position Sensor replacement and problems
either you have to reset the new one or try to disconnect the negative of battery and connect it again in order to reset the basic setting of that,,,thanks
Nov 30, 2013 | 2003 Nissan Altima
The tv worked for about 30 minutes now the screen is blank but sound is still working and the lamp light is blinking, what do i need to do to fix?
bigjohnson4,
It sounds like you need to replace the lamp and perhaps reset the unit. I have tips to cover all of the problems.
How to replace the lamp:
http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv
What to do if the unit will still not work:
http://www.fixya.com/support/r8482944-after_lamp_replacement_projection_tv
How to reset the lamp: Using the FixYa seach engine, input "Lamp reset procedures for (your manufacturer)" and you should get the proper procedure.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 28, 2011 | Toshiba 56HM66 56" Projection HDTV
Printer problem
E24 Purge unit error
Reset procedure:
Service mode operation procedures :
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Reset except for the followings:
- USB serial number
- Destination setting
- Waste ink counter
May 11, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon ip pixma 1500
hi dear
try this methode
service mode. (Waiting formenu selection)
button pressing
procedures below.
procedures below.
that's all
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
My TI turns itself off and resets its RAM whenever I hit an arrow key.
Sorry that you all are having issues with your calculator. Try the reset procedures for your units. Reset procedures can be found in Texas Instruments Knowledge Base which can be found at the following website:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=72521&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG1012A709F38464426C8B7F954BAD10F30F8264D7A42C7ECAC14E43D33C62440B0C3439BADB85CBF64291010A4860F183F8
Note: Even though the reset procedures are for units that do not turn on, they can still be helpful.
Hopefully that works, if not, you can always contact TI by calling 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time.
Dec 23, 2007 | Texas Instruments TI-83 Plus Calculator
E 5 error
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
IF THIS STEPS DOESN'T WORK, YOU NEED TO BRING THE UNIT TO YOUR NEAREST SERVICE CENTER...
Oct 22, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Toshiba TDP-S8 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
