Question about Panasonic Viera TH-42PZ80U Plasma TV
Panasonic lcd tv TX32LX75C AFTER 40TO45 MINITS TV SCREEN BLANK SOUND REMAIN TWOTO FOUR SECOND & TV DEAD RED LIGHT FLASH 2 TIMES GET ME THE SOLUTION
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
dsacco86
  • 1077 Answers
SOURCE: TV clicked and went blank...no picture, no sound.
Most problems with TV not turning ON is a power supply related problem. The relay click are a normal process that powers up the circuit boards. Right now the TV is most likely in " Protection Mode ". The TV detected a bad circuit board and it will prevent the TV from fully turning ON. This keeps the other circuit board from being damaged. The power light blinking is a code.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, blinking light codes, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
dsacco86
  • 1077 Answers
SOURCE: Panasonic TH-42PD50U RED ON LIGHT BLINKS BUT WON'T STAY ON
Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
Posted on Jul 14, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic TH-50PZ80U tv, error- 2 blinks
1. Reseating the connector P25 may solve the problem. If it does not.
2. Unplug the unit andd disconnect the connectors A5, A6, and A7. Apply power to the TV. If a White screen comes up and all voltages check normal, replace the P board.
3. If the TV stays on after isolating the SC board, then replace the SC board and the D board; it is likely that the fuse on the D board is blown.
Posted on Dec 06, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
TV goes to blank screen standby after one second of normal functioning green power light on. When in standby state, the TV is blank like it's off and the red standby light blinks FOUR times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 16, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
My panasonic plasma hd tv red light flashes 10 times and will not come on
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
Mar 31, 2013 | Televison & Video
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
Mar 04, 2011 | Televison & Video
Screen become blank after several seconds
Take a flash light to the frount of the unit if you see the screen then you got a backlight issue or one of the inverter boards mihgt be the cause here.
It would be considerate when your passing threw fixya to leave a rating and feedback
May 24, 2010 | Astar LTV-3201 32 in. LCD Television
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Panasonic Viera TH-42PZ80U Plasma TV Logo
131 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
