Question about Cameras
How to remove the film door on Nikon N90 - Cameras
  • 667 Answers
Along the hinge side near the top, a small screw sticks out from the plastic end of the film door. (opened). Push the screw down with your finger to release on edge of the door and lift it free of the camera
Posted on May 04, 2008
How do i remove film from nikon lite zoom ed 130
First rewind film in canster then when you hear the click you are finished rewinding the pull up on left winder knob this will open the door keep holing up and let fil drop out walla you're done.
Oct 01, 2013 | Nikon Lite Touch Zoom 130ed 35mm Film...
Want a new rear film door for a F90X
http://uscamera.com/1b999-517.htm
That's for the back cover for the Nikon N90/N90S, which is what the F90/F90X are known as in North America.
Sep 28, 2010 | Nikon Cameras
Nikon f100 film won't advance
We will assume you know how to load the film to the red mark. If the film is not advancing a couple of things could be happening. When you close the back door it is not engaging the film to hold it against the take-up spool. If so then that needs to be fixed. The other thing to check is the left side where the film cartridge goes in, does it turn. If not it is binding the film cartridge. Nikon Film 1-800-645-6687
Apr 19, 2010 | Nikon F100 35mm SLR Camera
The film magazine stuck in the Canone EOS 10 camera, never happened that before, i could easily insert and remove the film. it's rewinded, luckily, but I need a new one to put there, + I'm afraid if I...
Nikon N75 or Canon EOS 10????????
How is the film stuck? Is the rear door stuck? Does the film door open?
As long as you do not damage the film canister, the film will be ok. If the door opens and the film is rewound, use something to pry out the top of the canister from the camera. Then you can remove the film.
Even a film roll of 36 should not get stuck. Check the cartridge are for anything sticky. Sometimes these older cameras get some sticky residue from decaying foam in the shutter area. This would be a good time to send it in for CLA - Clean, Lubricate, Adjust.
My own EOS 10 had that problem. If you can't get the film out, the repair shop will do that for you.
Jan 20, 2010 | Nikon N75 35mm SLR Camera
Film door latch broken
Nikon doesn't supply the film door any more. You can buy a repair kit from USCamera.com to replace the latch on the film door
Jan 02, 2010 | Nikon N6006 35mm SLR Camera
Looking to download N90 nikon film slr manual
http://www.butkus.org/chinon/nikon.htm
Sep 26, 2009 | Nikon Photography
Problem with loading film in my Nikon F60.
Draw the film all the way to the receiving spool. There's an 'eye' inside the film compartment to check that the film is loaded. When the film is not correctly loaded the camera thinks it's empty and rewinds the film.
Aug 08, 2009 | Nikon F60 35mm SLR Camera
FILM DOOR WILL NOT OPEN on nikon f2
The F2 has a door knob on the bottom cover. Flip out the handle and rotate it counter clockwise to open.
Apr 07, 2009 | Nikon Photography
Nikon F100, N90 & N80
"End" can be a message for "film over" or for a film jam in the cam. Did you check for this already?
Jul 26, 2008 | Nikon F100 with 28-80 and 70-300 lens 35mm...
How do I remove the film door on my Nikon N90
You should not have removed the screw. It sticks out for a reason. You push it down to release the top hinge of the door.
May 03, 2008 | Photography
Cameras Logo
78 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
