If the dome lights on your 2007 Hyundai Tucson do not come on when the driver's side or passenger doors are open, but they do work when you press the interior dome light buttons, there are a few things you can check to try to determine the cause of the issue:
Check the door switches: Make sure that the door switches, which are located on the inside of the doors, are working properly. If the switch is not working, it will not send a signal to the dome light to turn on when the door is opened.
Check the wiring: Check the wiring that connects the door switches to the dome light. Make sure that the wiring is not damaged or corroded, and that all connections are tight.
Check the dome light fuse: Check the fuse for the dome light in the vehicle's fuse box. If the fuse is blown, replace it with a new one of the same amperage.
Check the BCM(Body Control Module): The Body Control Module controls the door switches and the dome light. Make sure that the BCM is not malfunctioning.
Check the Sunroof switch: Make sure that the sunroof switch is not malfunctioning, sometimes that switch is used to turn on the dome light, if the switch is not working the dome light will not turn on.
It's important to have a professional technician to diagnose the issue and confirm what the problem is before trying to fix it. If you're not comfortable with troubleshooting the issue yourself, it's best to contact Hyundai dealership or a mechanic for further assistance. https://amzn.to/3XfuL5A
https://amzn.to/3XvaZTe
Your system is either out of sync on the control, or the air temperature control blend door is not moving due a failure of the door or its actuator motor.
charge the battery.
so that wnen rested it reads 12.6vdc. then it will start.
also check all fuses in both fuse boxes.
they might have tried hot wiring things (like on TV) and blew fuses.
the battery is first. no power, all toys and EFI go , dumb.
i turn on what light the head light switch.
most cars have a dome light feature for turning on the dome.
see the operators guide.
the dome turns on 3 ways (more)
any door open (each door has a jam switch to do that)
the lamp itself side of it switch on. (and a defeat switch , on most)
the dash lamp switch to do it from drivers seat.
A switch by the side of the indoor light normally is divided into several gear to feel it when the gear drive DOOR interior lights will be lit up want know more
I have the same problem with my 2006 acura tsx with the windows and cant figure it out...did you figure out what the problem is?...I think the child safty switch went thats all i can think of...pleasse write back thanks!
No it sounds more like your A/C evap drain may be stopped up. Of you had a heater core problem you would have a stong odor from the anti-freeze and it would be very noticable and some time cause moistuer on the windows. usually the Evap drain can be blown out from the bottom.
Don't let anyone sell your a heater core. The moisture on the carpet would be oily to the touch as well from the antifreeze.
turn the key on then push in on the plungers, also twist and turn them. with the key off the light is on a timer and will not go off right away. if the key is on the light should go on and off with plunger movment.
