Question about LG RU-42PX10 42 in. HD-Ready Plasma Television
Hi my LG RZ42PX11 is broken , saund is OK bat scren is 1/3 in the midel , flimer blu and red,hwat is the problem? reg:G.Flenmark.
  • Gunnar Flenmark Aug 20, 2010
    Hi sorry my bad englis,i hav blu and red lines on schreen,G.
    OK,i have red vertikal lines on scren,Volume is ok channel up/down ok, meibi its PDP 040130
    LVDS Logic 6870 qce 014B. Gunnar.
  • 4,889 Answers
Sorry, I did not understand your problem. What is "bat scren is 1/3 midel filmer blue and red"?
Posted on Aug 20, 2010
  • eagle338
    eagle338 Aug 20, 2010
    You either have faulty sustain board/Fauly Logic control board. Are all the controls functional? Like Volume up/down, channel up/down?
  • eagle338
    Its not the logic control board since all the controls are operational. It is definitely a fault on one of the certain boards. From what I have noticed in mosst cases this is usually caused by faulty capacitors on the y-sus/z-sus boards. If you want to try a component level repair then you should know how to solder. Now the question is do you know how to solder?
Rectifier wiring on 1990 115 merc
BLOCK YEL LEADS FROM STA TOP AND BOTTOM. YEL FROM
REG. TOP AND BOTTOM.
GUST JOINING THE WIRES.
CENTER POST USED FOR TACK WIRES.
REG REDS BAT AND START SOLINDO.
Jan 28, 2018 | Mercury Boating
Can u swap all the boards out of a new lg plasma into an old epdp panel
NO WAY---every model uses different boards--LG is even known to use different boards in sets with the same model number--those have a bar code label on them to id them for replacement.
May 16, 2012 | Televison & Video
Battery draws down during ride. volt meter reads only 9 volts. all other electric systems seem to be ok except one insterment light seems to be out (tach light) Is this likly to be an alternator output...
when running at bat use good vom 14 + volts .good bat volts non running 12.6 v .if not check wire to reg ..check that reg is grounded GOOD , bat in good shape ..them check for good assending voltage at stator plug. use ac setting on vom. 0-150 v will increase w/ rpms do not leave unplugged to long just to test..smell primary oil should not smell burnt I often replace reg & stator together.. harleytalking.com
Oct 19, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
Hi I have a LG 42' plasma, but it wont turn on. it does have power but just flashes the on-led green three times then goes back to red. I can here a relay click but not much else. Im guessing it could...
You are on the right track, Hopefully if you have some bad caps hope that they are obvious because you can have bad caps that look as good as a brand new one.
Sep 09, 2017 | Televison & Video
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
My blackbird has a new reg & bat and on my meter is charging ok..but the bat goes flat why
HI, FIRST THING TO CHECK IS, DOES THE BATTERY LOSES CHARGE WHEN IT IS DISCONECTED FROM THE BIKE, NOT THAT UNUSUAL TO HAVE A FAULTY BATTERY.
SECONDLY WHEN REPLACING THE BATTERY WITH THE KEY TURNED OFF DO YOU HAVE ANY SIGN OF DRAIN IN RESPECT OF A SPARK AT THE LEADS WHEN YOU TOUCH THE LIVE OR EARTH TO THE BATTERY POLE, THIS WOULD INDICATE A DRAIN
Dec 24, 2010 | 1999 Honda CBR 1100 XX Super blackbird
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Charging problem
Hi
As the battery & regulator/rectifier have been replaced, the only other things to check are :-
Continuity from reg/rect red wire to battery & to earth, then check for continuity between each of the 3 yellow wires, all should be the same resistance - if not the stator coils in the alternator are faulty
Ride safe
Bike-Doc
Please mark this as very helpful (if it has been!!)
May 06, 2010 | 2006 Yamaha V Star Classic
LG RZ42PX11 PICTURE PROBLEM.
I do not know who was helping you before but the problem you are having can be caused by three boards in the tv each by themselves or in combination. Those are the control board with part#6871QCH053G, the Y- board part #6871QYH036D or the Z-board part#6871QZH041B. Without being able to do voltage and signal measurements directly for you, the Z-board is likely the culprit here. But I will tell you that even experienced tv technicians find themselves swapping one or more of the boards until they fix the problem. I am assuming here of course that you have not had problems with your tv before. The part #s I have given you are for the improved boards that LG has assembled to take care of future similar problems and come with their latest training manual for technicians. God bless and good luck.
Jan 13, 2009 | LG 42PC3D 42 in. Plasma Television
LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
107 people viewed this question
