Question about Acer AL1916W 19" LCD Monitor
I have the acer AL 1916w monitor behind the monitor there are four holes available . i want to mount this monitor on the wall . so pls help how will i mount on wall by using this hole or any possibilities available to mount the monitor on wall .. regards SIDDIK . J
  • 11,361 Answers
They are Metric screw M4 or M5 from HD or LOWE's,
When you buy a wall mounting kit, it should come with the monting screw, do some research to what kind of mounting kit you are going ti buy that will have the mounting pattern that fit your monitor or if it has variable pattern that will accomodate your monitor.
User manula and support; http://support.acer-euro.com/drivers/monitor/al1916w.html
Watch out for caps going bad in your monitor also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 23, 2010
How do i set the monitor so the text and icons appear clean and crisp?
go to acer website and download driver for monitor or graphics monitor. Make sure you download AL 1916W and NOT AL1916. Make sure after, you set your resolution to 1440 x 900. That should do the trick.
Feb 03, 2011 | Acer AL1916W 19" LCD Monitor
ACER Al 1916W Asd service manual
dac-19m005 power light comes on then goes off
Jan 08, 2010 | Acer Computers & Internet
How do i attach a wall mount to the back of my 20" samsung?
Samsung wall mount bracket WMB 1900T adapts for four hole wall mounts. Fits 19" to 22" monitors. Price is $27-$42 at online stores.
Apr 09, 2009 | Samsung T200HD LCD Monitor
How do I remove the back from my acer al 1916W
face down the monitor over a soft surface to avoid scratches .Remove all screws that you can see.There are more screws that mount the leg to the monitor .Those are hidden you can not see.Covered by a little plastic cover shell.After you remove all the screws ,now you need to remove the back cover from the monitor .using a flat screw driver or another slim tool begin from one side .stick the screw driver into join line between the front and back cover and twist it gently.this is hard part of the operation.You got to be careful .try to loose one side first then other sides ll be easier.
Apr 06, 2009 | Acer AL1916W 19" LCD Monitor
Mounting an Acer AL2416 to the wall
Hello Poet,
I recently purchased two of the Acer AL2416W to mount onto a monitor stand. I ran into the same problem, it looks as though you have to remove the entire rear of the Monitor to take the factory leg off. I believe I was trying to make it too complex, just gently pry the rear cover off of the hinge this will expose 4 screws remove these and you are all set.
Mark
Jul 02, 2008 | Acer AL2416W 24 in. LCD Television
Repairing the MB for the (Acer) AL1916 monitor
http://www.eletromaniacos.com/Downloads/Monitores/Acer/acer-AL1916v.pdf
Apr 24, 2008 | Acer AL1916W 19" LCD Monitor
Acer 1916w dissassembly
dear alanwilson04
if your monitor is under waranty then it is better to give to the shop from you have purchased.
if not then you call a qualified person to solve the problem because working inside the monitor is dangerous
Mar 04, 2008 | Acer AL1916W 19" LCD Monitor
Hoe do I remove teh attached stand on an ACER AL 1913?
Where the footpiece joins up with the screen, you'll find a round cover from left to right which just clips in. carefully squeeze the ends and pull away untill released. under the cover you'll find four screws that holds the footpiece and screen together. Good Luck, jus004
Jan 05, 2008 | Acer AL1913 19" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
424 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
