Question about RCA Televison & Video
I have no auto converge menu - RCA Televison & Video
  • RCA Master
  • 8,617 Answers
Very easy repair. You can get the repair kit called the ITC222 convergence option missing repair kit from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Posted on Aug 20, 2010
Double vision, believe one of the guns went bad
If the auto convergence feature is still listted under the setup menu then you need a convergence power supply board. If the auto convergence feature is no longer listed under the setup menu then you just need a repair kit. You can get either one from www.tvrepairworld.com
Sep 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
50 inch rear projection hd ready model r52wm24 colors have separated and picture is bowed toward the middle top & bottom
sounds like the auto convergence option has disappeared from the set up menu. Press menu and scroll to setup and then enter setup menu and see if the auto convergence is still listed there or has it disappeared?
Jul 30, 2011 | RCA Televison & Video
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
TV NEEDS TO BE RELINED ;IDONT KNOW HOW/
The Auto convergence feature listed under the setup menu will do it automatically. A common problem is the auto convergence feature will disappear from the setup menu. If yours has disappeared there is the convergence option missing repair kit from www.tvrepairworld.com will solve the issue.
Jun 14, 2011 | RCA R56WH76 Projection Television
How do I adjust the convergance? I have a shadowing problem
Press menu on the remote then scroll down to setup then enter setup. The auto convergence feature is listed there which will reset it automatically. If auto convergence disappeared from the setup menu then you will need the RCA convergence option missing repair kit from www.tvrepairworld.com which does contain the instructions.
Jun 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca big screen 5-8 years old, power shut off this morning while watching then when I powered it back up now blurry and has a red and green outline around everything onscreen
If you have the original remote to that tv, click on menu, then select set up from the on screen menu, then select convergence. you might see auto convergence as well as manual for blue and red convergence.
If you see Auto, select it, this will line up your tubes.
If no auto convergence, you will have to select each one, and follow the instructions to aline your tubes.
Oct 09, 2010 | RCA R52WM24 52" HDTV Projection Television
Green auto convergence
The master convergence settings have to be close for the Autoconvergence to work. If they are not you need a technician to go into the service menu and adjust them.This is a long job and you can't do it yourself.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Auto Convergence Problem, no menu option, 3d looking picture
yes the board components are out.not to replace whole board only two convergence ic on the board needs replacement. they are not at all costly this link which is mentioned belkow has all the instructions to replace the ic on the board just click it and follow the instructions  http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Mar 07, 2009 | RCA R52WH73 Projection Television
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Auto convergence
this point to the special fuse fl231 a small rectangular fusable link. .4 amps if you can get this fuse and you can solder repairs is not to difficult.. you have to resolder connections that cause this fuse to blow
Jun 20, 2008 | RCA HD52W58 52" TV
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
