Question about Magic Chef Chest Freezer MCCF5WBX
Freezer not cooling but the power and run lights are on. temp set between 3 and 4. the coils are very clean and the compressor is warm. doesn't seem to be any difference when going up or down with the thermostat. also didn't see any signs of the coolant leaking or been leaking.
  • msconsign Aug 20, 2010
    ok.... thank you for getting back to me. I am an automotive master tech by trade so i have looked for ports to check and charge the unit but see none. where does one re-charge the freon at or do I have to take it to a pro? and how much on an average does it run to check and charge the freon?
    Very helpful and quick to respond. Answered my all my questions.
  • 2,382 Answers
Hi, you have made most out of the work by troubleshooting the freezer to identify the likely cause of problem associated with the freezer. If all you have said so far about the freezer is right, then it leaves me with no other option than to suggest that you have a low freon in the compressor which you probably need to refill for the freezer to start cooling again...
Posted on Aug 20, 2010
  • 1 more comment
  • Tunde Autos
    Tunde Autos Aug 20, 2010
    You have to call in a refrigerator tech to come and refill the compressor and it should cost less than $100
    Will do.. thank you for all your time. Great job
  • Tunde Autos
    O.k, you can now rate and accept the solution.......
Mdle 21571 upright Kenmore Freezer seems to run all the time and seems warm to the touch. It is keeping cold but the running all the time doesn't seem right.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | Kenmore Freezers
Whirlpool upright freezer - 10+ yrs. old - light on - doesn't cool. Told freon leaking and not worth / couldn't repair??
heatman101
Aug 28, 2011 | GE 20.3 cu. ft. / 575 liter Upright...
I believe my freezer has stopped freezing and the digital temp setting on the outside of the freezer is not working
heatman101
Aug 02, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Purchased ColdTechCommercial Freezer CFD-3F from private seller. Freezer was used for 9 months then sat in a garage for almost two years. Freezer turns on and runs, but doesn't cool at all- in fact,...
Hose underneath is probably for condensation and defrost water. If the compressor is not coming on, there is a good chance it is the thermostat. There is always the possibility that there is a refrigerant leak and it leaked down over the 2 year period. This is where I would start.
Jul 08, 2017 | Coldtech 72 cu. ft. / 2039 liter Upright...
Why doesn't the freezer stay cold if the temp gauges is set to cold(fridge)
heatman101
Apr 20, 2011 | GE Freezers
I have model No FZA34G - Frost free freezer. The red light marked "high temp" has come on and all the food has defrosted. I can't find the manual.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 30, 2010 | Hotpoint Freezers
Not freezing
Either the defrost circuit has failed or the refrigerant is low - my money is on the defrost circuit.
Most defrost circuits have three main parts:
1) defrost electric heating coil
2) defrost terminator
3) defrost timer.
The heating coil and terminator are in the freezer compartment - behind a protective panel. The heater is usually piggy-backed on the freezer coil and the terminator is in contact with the freezer coil to detect its temperature. The defrost timer is a simple assembly of a clock motor with switch contacts that can be located anywhere the manufacturer desires. The timer turns on or enables the defrost circuit every 8 or so hours for up to 30 minutes give or take.
When the timer has enabled the defrost cycle, the cooling mode ceases; the compressor shuts off and power is sent through the terminator to the heater. The heater warms and melts any ice build up on the freezer coil. The water drips to a pan and flows down the tube to a pan under the fridge - where it is evaporated off. The heater warms the freezer coil until either a) the timer returns to cooling mode or b) the terminator senses a preset rising temperature on the freezer coil. Once either condition is present, power is interupted and heating stops. The compressor is energized through the adjustable thermostat in your fridge. Since it is warm, the compressor turns on and cooling begins.
If any of the components listed above (1,2 or 3) have failed, the defrost cycle never warms the freezer coil and the ice never melts to clear the freezer coil as intended. Air can not be circulated through the freezer coil since it is choked with ice, so even though the compressor runs, the fridge and freezer spaces never get colder. The adjustable thermostat never sees the temperature you've set so the compressor never shuts off.
Water dripping in the fridge is melting ice from the freezer space - as the freezer is not getting colder - only the protected space around the freezer coil is.
To fix this, you'll have to get the service manual or schematics for the fridge to determine where the parts are located and do some troubleshooting with a multimeter after disassembling the freezer compartment and wherever else to access the timer if needed. This is not a good first appliance repair job for a DIYer due to the danger of refrigerant and testing live electrical parts in closed in spaces.
I hope this helps.
May 20, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Check to see if the cooling coils are clean. Dust is a great insulator and may be keeping the coils from doing their job.
G.
Apr 15, 2010 | Magic Chef Chest Freezer MCCF5WBX
Upright freezer quit cooling, compressor runs, interior fan runs. copper line from compressors, 1 is warm and 1 at room temp
Hi..
Try to check this
Good luck!!!
Regards
PCmania
Jul 08, 2009 | Frigidaire Freezers
Dead Upright Frigidaire Freezer
YOU MOST LIKELY HAVE A FREON LEAK AND RUNNING THE FREEZER WITHOUT FREON IN IT WILL KILL THE COMPRESSOR UNLESS YOU UNPLUG IT AND GET IT FIXED,THE COILS ON MOST FREEZERS ARE IN THE SIDE WALLS SO YOU DON'T HAVE TO CLEAN THEM LIKE ON YOUR FRIG.HOPE THIS HELPS-MIKE
Jun 16, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Magic Chef Chest Freezer MCCF5WBX Logo
1,080 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
