Question about Sony STR-DA3300ES
I have a Sony DA3300ES Receiver Amp that suddenly goes into Protector mode and shuts off. I have disconnected all speaker cables and interfaces and the problem still exists. It goes into Protector mode after 5-10 seconds of switch on. Any assistance would be appreciated. Regards Rob Masters
  • Sony Master
  • 1,527 Answers
Hello it sound like the output transistor may blown or 1 of the capacitor could have pop or swellled up
regards
shaun
Posted on Aug 20, 2010
I have sony radio.but now is display flashing protector and I cant play anything ,how I can solve this plobleme
Disconnect the receiver for at least 30 seconds..Disconnect all speakers.inspdct each speaker cable and make sure all wires are twisted tight.one little wire sticking out can make bad contact with unit.turn on reciver..hook up front speaker wires and then one at a time hook the rest up.hooking them up one at a time will show and tell if you have a bad external speaker or wire problem causing your receiver to go into surgery protection mode.thats why it is important to twist your speakers cords up properly inspecting each one.
You can run your receiver a fourth of max volume for 20-30 minutes to warm up checking each connection.
Apr 09, 2017 | Sony Audio Players & Recorders
How do I do a factory reset on Sony STR-DA3300ES receiver when the published method in the manual doesn't work?
While holding down TUNING MODE, press POWER on the receiver. All preset stations will be erased when you change
the tuning scale.
See some test modes
MEMORY CLEARING MODE
All preset contents are cleared when this mode is activated. Use
this mode before returning the product to clients upon completion
of repair.
Procedure:
1. While pressing the [TONE MODE] and [DMPORT] buttons, press
the [POWER] button to turn on the main power.
2. The message "MEMORY CLEARING***" appears and the
memories are reset to the default values.
3. When done, the message "MEMORY CLEARED*"
If you are a geek then try the SUPER MENU MODE .
Understand how to enter and exit the menu,
then See if Super reset on page 25 helps
Sony STR DA3300ES Service Manual Page 25
Oct 07, 2016 | Sony STR-DA3300ES
Kenwood VR 605 power light flashes
CHECK FOR CLEARED COOLING VENTS & FOR PROPERLY WORKING COOLING FANS. THIS WILL CAUSE SHUTDOWN OF THE UNIT. IF ITS ALL CLEAR, YOU PROBABLY HAVE A POWER SUPPLY ISSUE.
Dec 10, 2013 | Kenwood VR-605 Receiver
My sony receiver STR-DE135 is showing a protector message
Check for shorted speaker cables, or even a bad speaker. I'd start by disconnecting all speakers, see if the indicator goes out. If so, try one speaker at a time until you find which channel is bad, and then examine the cables carefully for things like a stray wire strand. Less likely, but possible is a shorted speaker. If you disconnect them all, and still have the protector circuit on, it's an internal issue, and you're going to need a technician.
May 30, 2011 | Sony STR-DE135 Receiver
This amp wwhen turned on, dosplays 'PROTECTOR' on teh display, what is this telling me?
Disconnect all the speakers and unplug it for 5 minutes. Then turn it back on without any speakers plugged in. If it doesn't say protector, then you either have a shorted out speaker or wire. The amp is in protection mode which is designed to keep it from burning up. If it still says protection, then it will need to be repaired as it is too late.
Dec 19, 2009 | Sony STR-DE535 Receiver
Whenever a little bass sound - explosions, gunfire, helicopter blades, etc., ''PROTECTOR'' flashes on LED and shuts down receiver. Seems to happen more frequently lately. Subwoofer cable sturdy, no...
The protection feature on these units will shut off the receiver when there is too much power draw or when a speaker wire is touching another wire. First, check all of your speaker connections and make sure the wires are nicely twisted and inserted into the speaker and receiver with no stray wires touching. Secondly, if this doesn't correct the problem, try going into your speaker settings menu on your receiver and select "small" for each speaker. Let your sub handle the bass. The sub cable should have no effect on the protection feature of the receiver. The speaker wires, however, are the most common culprit of a receiver turning off (protector). Hope this helps.
May 03, 2009 | Sony Televison & Video
HI, I have a sony v555es amp and it gives me the following error message "protector OPT.....please power off"
You might be trying to push it too hard, or you might have a short somewhere. Disconnect everything from the reciever except its power cord and turn it on. If it still goes into protect mode, then try to find a reset switch (not sure if this is on the Sony, some recievers have them). If it's NOT in protect mode, then you had a speaker wire shorting out on the back. Make sure that you don't have any stray wires when you connect the cables on the back of your receiver. It only takes one strand of copper to short out the amp section. If that doesn't work then pull the top cover off and chech the fuses out. One of them might be blown.
Tom
Jan 01, 2009 | Sony STR-V555ES Receiver
Help
check/replace your speaker wires. If a wire came loose, it will go into "protect" mode and shut down, to protect from a short circuit.
Jun 16, 2008 | Sony STR-DE525
Protector flashing
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Oct 05, 2007 | Sony STR-GA7ES
Protector
If you took all the speakers off the reciver then it still goes into protect, the reciver detects DC on the output lines. That means there is a short in the output stage of the amp. It could be an output device, or a diffencal Transistor. If you can trouble shoot solid state electronics then you should be able to find the faulty, but if not your experienced at electronic repair, am afraid it may cost more then the reciveris worth. Good Luck PS please dont forget to rate this thread
Oct 23, 2006 | Sony STR-DE545 Receiver
Sony STR-DA3300ES Logo
486 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
