Pc will not turn on, blue light flashes on power button and fans turn for a sec. then nothing
  • 644 Answers
The power pack has failed and needs to be replaced, they are easy to change, take the side panel of the tower, there should be 2-3 screws at the back holding in place, the power supply will be in the top corner with a bunch of wires coming out of it, unplug all wires from the motherboard and peripherals inside the pc ensuring you write down where each one goes.
There are 4 screws holding the power supply in place, they are placed at the back of the tower, near the top, undo the screws and the power supply should just pull out of the case, take the power supply to your local store and get a replacement, normally they are priced between ?15-50, put the new one back in the same way and try to boot the pc, it should now be fine.
hope this helps.
Posted on Aug 21, 2010
Pc not starting When I press power button on cpu
If you are not getting the computer to start up but you are getting the fans to whir for a moment and the keyboard lights to flash, then that means that you probably have a bad motherboard. If you had a bad power supply, most likely none of these secondary indicators would be present. I would advise taking the computer to a local computer repair shop and having a professional investigate the problem. More than likely, he will be able to tell you the cause of your problem in short order.
Oct 12, 2014 | Computers & Internet
Pc not starting When I press power button on cpu the fans on motherboard,rear ,power supply starts but no lights in front and nothing on display Also The lights in keyboard and mouse flashes for 1 sec then...
Hey
Do you overlock your pc? If yes there is a possibility it's your CPU that is dead.
It also could mean you have a bad motherboard or bad memory stick.
Check your memori first just un
I have an HP Pavillion dv9000 the blue lights come on for just a sec and then nothing. It will turn on periodically and works great when it on. But that is the problem it hardly ever does. Just the blue...
This could be lots of things. so lets try the easiest.
Blow out the dust in and around the fan(s)
replace the AC power cord and/or battery.
replace hard drive
and the big one replace Motherboard (which i done once in my lifetime)*
* = most likely not it.
Nov 02, 2010 | HP Pavilion dv9000z Notebook
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
When I press the power button the pc runs the fans
You're power supply is on the way of going out if it's not already. Get a new one as soon as possible. If it started after a while it sounds like it was overheated and starting it again may have been the final straw.
Nov 10, 2009 | Thermaltake Toughpower 750-Watt Power...
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Cpu not powering press on button lights flash fans turn for a sec
It a issue with the power supply or the SMPS. Change the SMPS of same capacity and then it should work..............sodeep
Jul 30, 2009 | Compaq Presario 5000 PC Desktop
Hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Jul 16, 2008 | HP Pavilion a1250n (EG194AA) PC Desktop
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
