Question about Jenn-Air Kitchen Ranges
We have an error code on the display that we can not get to clear. (5Ab bATH) This is a Model Series: JDR8895. Freestanding Double Oven Range
Saw this somewhere else. You have to turn off the Sabbath mode. Not sure how, check manual.
Posted on May 11, 2008
What does 5AB mean on clock?
Your display is actually reading "SAB". This is an indication of a mode of operation rather than an error code. The following link explains:
http://www.fixya.com/support/r3608491-sabb_or_sab_explanation_kitchen_ranges
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features and operator, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct, you need to press and hold the CLOCK button for 3 seconds to clear the Sabbath Mode. "Sab" will flash for about 5 seconds, then return to normal display.
Oct 22, 2015 | Amana 30" Self Cleaning Electric Range...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
What does 5ab bath mean?
it is actually saying Sabbath. Go to your owners manual and it will tell you how to take it out of that mode. Have a nice night. Ann
Nov 26, 2011 | Whirlpool SF367 Gas Kitchen Range
I have a code 5ab on the panel my model nuber is MGR5775QDS its a 30 inch free standing gas stove.
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/2348-maytag-oven-weird-error-code-5ab.html#ixzz1GLM0d1gp
Mar 12, 2011 | Maytag MGR5775QDS Dual Fuel (Electric and...
My Maytag Gemini oven is displaying an F9-2 error code...I believe this has to do with the upper oven door lock mechanism...anything I can do, or does this require a service call?
F9-2 error code indicates:
  1. Door latch motor failure/jammed. Latch motor switch failure.
  2. Oven control software failure, or component failure(stuck relay).
  3. Wiring problem.
  • Press the clear key.
  • If the Clear key does not eliminate the problem, turn off the power to the range for 30 seconds, then turn the power back on.
  • It is most likely to have a failed or misaligned door lock switch.
Feb 06, 2011 | Maytag Gemini 30" Self-Cleaning...
My Jen air double oven freestanding range model series JDR8895 ELECTRICAL SYSTEM IS NOT working and I live in Panama can you help me???
If absolutely nothing is working the first thing top check is the electrical circuit breaker/fuse panel for the house. Make sure full voltage is going to the range.
Remove the rear panel where the wires come in to the range and look at the terminals. Something may be broken or shorted in there.
There are no fuses or reset buttons in this range that would stop the oven and the surface burners from working at the same time.
Nov 13, 2009 | Kitchen Ranges
5Ab error code for a Maytag Electric Range
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models you simply press and hold the "Clock" button for 5 seconds. These instructions should be in your owner's manual.
If this does not correct the problem for you, please post back with your model number (located on the back of the range or around the oven door opening) so that I may be able to assist you better. I hope this helps you.
Nov 01, 2009 | Maytag MER5775Q Electric Kitchen Range
What do I do? Model Series: JDR8895
try turning off your breaker for 30 secs then back on then set clock
Dec 15, 2007 | Jenn-Air JJW8230D Electric Double Oven
Kitchen Ranges Logo
310 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
