Question about Maytag MSD2756G Side by Side Refrigerator
Freezer keeps icing up. thawed it out and now it has frozen up again in approx 3 weeks. what is going on
    President:
  • 1,891 Answers
This will go on & on till you correct the cause . the heater or defrost thermo are not working . or oth;er is a d c on this model i would repl the terminator and if that does not control it look at t he a d c .. mm
Posted on Aug 20, 2010
Testimonial: "Thanks for the help"
Our Whirlpool upright freezer has a sheet of ice in bottom at drain--why?
Melt it again, and check it runs down the small drain hole, If not, clear the hole with a drinking straw. If it keeps freexing up, you may need an auxiliary heater added to the drain hole.
May 24, 2014 | Freezers
Water not going to ice machine
We had this problem with our ice maker last week. We could get water through the door water dispenser but it stopped making ice.
We had read that the line could be frozen and that was the case.
We have a KitchenAid Superba and the easiest way to thaw it out was to remove the two screws holding the water hose elbow into the back of the freezer (pull the fridge out away from the wall to access it). It will come out with about a 5-6 inch long hard plastic tube which goes through the back freezer wall and joins with an aluminum tube (which may also be plugged with ice) that reaches the ice maker. Looking inside the tube we could see the ice blockage. Heating it up with a hair dryer made the ice plug drop right out. We had tried to thaw it out by heating the tube inside the freezer, but the ice plug was actually in the wall part of the freezer and we wouldn't have been able to thaw it out from the inside (short of shutting the refrigerator off). When the heat was applied...a 3 inch plug of ice dropped out of the tube, and there was even a very small piece of ice blocking the elbow part. We wouldn't have been able to thaw that area out without taking it apart.
Feb 16, 2011 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Amana refrigerator, bottom freezer. Back keeps icing up. I have unplugged and thawed it twice, within 2 weeks it is frozen again and freezer warm
This is a defrost problem most likely caused by a defective defrost thermostat. It is located in the freezer compartment behind back wall on top right hand side of coils and usually has a brown and an orange wire connecting to it. It should have continuity when checking with a volt/ohm meter when it is frozen and read open when it is warm.
I have seen many of the newer electronic temperature model bottom mounts with defective control boards as well that cause the fridge to skip the defrost cycle.
Jun 14, 2010 | Amana Refrigerators
Maytag Bottom Freezer not working
Maybe fan in freezer not running to circulate air.
Aug 28, 2017 | Maytag MBF2556HEW / MBF2556HEB /...
In-door water dispenser not working. tried lowering temp in frig to thaw line. Worked, but now line seems frozen again. ice in icemaker holder seems to be thawing and freezer is accumulating frost/frozen...
Defrost the freezer completely. Make sure the doors are sealed completely when shut. After defrosting plug back in and make sure the fan and the self defroster is functioning (your owner's manual should tell you how to reset the defrost timer). the problem may lay within the defrost system, and/or door seals and/or interior circulating fan.
Apr 30, 2010 | Refrigerators
Freezer keeps thawing. There was an ice build up.
Check the "flap" in the door where the ice is released. If it has come undone it will thaw the ice in the maker and into the freezer...
Jul 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is  frozen or bad what you havwe discribed wil bew the result.
Nov 26, 2008 | Whirlpool Refrigerators
Whirlpool gladiator garage freezer/refrigerator (top)
Remove the back liner and wall (more details on this below if you need them) to expose the iced up drain line (only 1) on the right side center inside the aluminum drain pan (Directly behind the bottom right side vent that goes into the freezer compartment). Thaw it out so that it will allow water to drain off (slow way -turn off unit for hours, not quite so slow - spoon in hot water - use towels to keep as much of the water from running into the lower freezer) When the drain is clear and water is draining freely, take light qauge copper wire (t-stat or low volt) and feed it down the drain approx 3 - 4 feet and then wrap the end of it tightly around the heavy defrost bar located just above the the drain hole (this bar resembles an oven element or dishwasher heater element and circles the entire freezer coil). Put several tight wraps on it. This will transfer some of the heat from the defrost cycle down into the drain line and hopefully solve your problem. If the coils are totally iced up you may have a defrost cycle problem and if so this solution won't work) reinstall all liners and wiring and you're done
removing the back wall (if you are unsure) take of plate located at upper left side of the back wall (2 short screws) to expose the wire harness- separate the main connectors) remove the 6 fasteners attaching the back metal liner wall (4 long & 2 short - the short ones go to outside lower holes) . and remove the bottom plastic liner tray (just lifts out) and the short plastic base wall at the back bottom of the compartment ( it may be iced in and hard to remove- be careful) remove the stryofoam insulating liner. Again it may be iced in and frozen to the unit so be careful and if necessary use warm water to thaw it out. This will expose the inner liner wall and the lower drain pan and line. If you see that the bottom of the coils are iced up you may want to remove the inner liner and defrost the coils but this it not usually the case and you can leave it in place. Again, if the coils are totally iced up you may have a defrost cycle problem and if so this solution won't work)
Jun 12, 2008 | Whirlpool Gladiator Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
373 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
