Question about Miele 24 in. G865 Built-in Dishwasher
Door has small leak. Needs new gasket around the door.
  • Miele Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 20, 2010
Gasket is leaking on LG refrigerator's freezer door
Generally you can just pull off the old gasket when the new one arrives, they sit in a small channel which you can use a thin screw driver to push it into gently, or the other one has a panel that holds the gasket in which needs to be unscrewed to remove the gasket. My best guess would be the first one. It takes time to put the gasket on so be patient when pushing it into the track, a thin blunt tool would be best
Sep 07, 2012 | LG Refrigerators
Tip
My Dishwasher is Leaking
This advice is dishwashers exhibiting leakage around the door. In the majority of cases this may be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps.
The silverware tray (if located along the left or right side) can also contribute to causing damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub.
Some other items that can contribute to leaking are:
1. A dishwasher that is not level, which causes the door not to seal properly.
2. The inner door panel being warped causing the door facing not to be even for the gasket to seat properly.
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being diverted over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
NOTE: Most dishwashers do not have a seal across the front lip of the tub. That's why it's important to have a good door seal and to load it properly.
If you've loaded the dishwasher properly and confirmed it is level (front to back and side to side), then here are your options:
1. Replace the inner door panel at a cost of over $100.
2. Replace the door seal at a cost of about $35-$40.
NOTE: I would pursue the cheaper option, first. Its also the much simpler option. To replace the door seal, follow these steps:
1. Pull the old door seal from the groove around the wash tub facing. Take note of which surface area of the gasket is inserted in the groove and which surface is facing the door. It may not seal properly if you install the gasket the wrong way.
2. Clean the area really well to ensure there are no food debris or soap deposits. Also clean the inner door area where the door meets the gasket. You need a clean surface for the best results.
3. Locate the center mark of the new gasket. This will be a small paint spot or small groove on the gasket (this surface is the side of the gasket that will be inserted in the groove around the tub facing). If there is no center mark, fold the gasket in half and mark the location with some chalk, or hold with your fingers.
4. Locate the top center part of the wash tub facing and align the center mark of the door gasket at that point. Begin pushing the gasket into the groove with your hands and work your way around and down along each side.
5. Make sure the gasket is inserted all the way around the tub facing to the point where it meets the wash tub bottom. You can pull the gasket out and readjust as necessary.
NOTE: Some manufacturers include a gasket epoxy that is applied to the gasket before seating. If your gasket does not come with this sealant, it does not require it.
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges.
on Mar 07, 2010 | Dishwashers
Tip
My Dishwasher Leaks
I hope this information is found to be helpful.
on Dec 01, 2009 | Dishwashers
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Dishwasher keeps leaking from door
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Jun 22, 2011 | Bosch SHU9915UC Dishwasher
Hi, I have a small leak at the bottom right hand corner of the door. If you push in on the door while it's running it stops and the noise level goes down. Is there an adjustment for the door or would it...
No adjustment. Try cleanig door gasket. If still leaks hinge probably got bent from leaning on door. Or door got bent. Needs to be taken apart to find cause for problem.
Sep 27, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
Duet leaking out the front door. They replaced
Hello LPeck, This is a pretty common issue with all front loading washers. Typically it has to do with the door bellows (gasket) that seals the door to the washer cabinet.
First, look very carefully at the gasket all the way around, using a flashlight. Pay close attention to the area where the water flows into the washer. This is usually located on the upper part of the gasket and sometimes the water inlet port gets the gasket moved out of place and when the water is flowing into the washer, it can leak outside of the gasket. Make sure that the gasket is properly located around the water inlet port and that the gasket does NOT extend past the water nozzle.
The other thing to do is again look very carefully at the entire gasket for small cuts or tears that might be allowing water to leak out. Even a small cut can allow alot of water to leak out of the wash tub, so carefully push/pull the gasket with your fingers while shining the flashlight onto it.
In almost all cases, it is a cut or torn gasket that is the source of the leak.
This is an easy self-service repair, only requiring a few basic hand tools to remove the gasket bellows from the washer cabinet and inner wash tub. Just fold the back lip from the washer cabinet and you'll see the retainer wire that holds the bellows onto the cabinet. With that removed, you can then slip the bellows gasker off the cabinet lip and see and get at the inner wash tub retaining clamp. Typically held on with a large diameter hose clamp. Remove that and you're ready to install the new one in the reverse order.
Just be sure to let the new gasket lay out to help get most of the kinks out of it, from being in the small shipping box, and install it slowly and carefully, so not to put any cuts in it.
This will save you around $150 +/- instead of having a service tech do the installation/repair for you.
If you want to see and order the part yourself, you can go to the following link to see the gasket and how it is installed. You can order it online from sears, or any place you wish.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GHW9150PW0&productCategoryId=0153200&brandId=1198&brandDescription=WHIRLPOOL&modelName=RESIDENTIAL-WASHER&diagramPageId=00002&componentDescription=DOOR%20AND%20LATCH%20PARTS&documentId=W0501061&blt=06
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I noticed water on the floor (right corner) and my concern is that I have hardwood floors. It is not a lot that I can see but my concern is that water is leaking underneath where I can't see. It is 8yrs...
Are you sure the water is coming from underneath the dishwasher? From the symptoms you described, this sounds like it could be caused by a worn door seal. Over time, these seals compress to the point where they no longer seal correctly, or food particles and grime get caught between the door and seal and leave small air gaps. The silverware tray (if located along the left or right side) can also cause damage to the door seal as utensils get caught on the seal surface as you roll the lower rack in and out of the tub. As water splashes up against the inner door facing it rolls out the bottom of the door, or down along the sides instead of staying in the tub. Some other items that can contribute to leaking are:
3, Dish placement. If you place bowls, serving trays and large tumblers in the front row of the bottom rack on some dishwashers it can contribute to water being deflected over the front edge of the tub and out the bottom of the door (Believe it or not, I've seen it happen).
1. Replace the inner door panel at a cost of about $130.
If the leak IS coming from underneath the dishwasher, you will need to remove the lower toe panel under the door and start the dishwasher to confirm wher eit may be coming from and at what point in the cycle it occurs (i.e., does it leak during the initial fill, during the wash cycle, or during the drain cycle). It will be much easier to determine a cause if you can narrow down the symptoms. Leaks under a dishwasher usually come from leaking hoses, or leaking grommets where the heating element is installed. In a worse case scenario, the tub could be cracked or have a hole melted through it (if plastic) from utensils that end up on the heating element during the drying cycle and heat up to melt the tub. You will need to do a thorough inspection and post back with the results, so that I may be able to advise you further if this is the case. If you need parts, they can be purchased from any of the following websites:
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
Use whatever parts source you like, but I have found these to be the cheapest and most reliable sites to order parts from. Shop all of them for the best price.
NOTE: The inner door panel is listed under the Door Parts section. The tub gasket will be listed under the Tub Parts section.
If the model number you have this listed under is correct, the part number for the door gasket is 902894. The part number for the inner door assembly is dependent upon your serial number.
I think I would pursue the cheaper option, first. Its also the much simpler option. Since your dishwasher is 8 years old, it is highly likely the door gasket is worn and needs to be replaced. To replace the door seal, follow these steps:
This repair should take you about 30 minutes or less to complete. Its simple and requires no tools. The door will be tough the shut for a while until the gasket compresses and takes the door shape. Do not slam the door if it becomes difficult to shut. Simply close the door and the push firmly at the point just above the door latch until the latch clicks. Slamming the door can damage the control panel components, the door latch and/or the hinges. NOTE: I personally own a Maytag model such as yours and experienced the same problem. Replacing the door gasket solved the problem for me. It may for you, too. If you have questions, or require additional assistance, please let me know. I hope this helps you.
Sep 30, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Front loader washer leaks from bottom center of door osmetimes
Check inside the door on the bellows gasket to make sure the inlet area (normally at the 10 o'clock position) is properly positioned around the water inlet, sometimes these work themselves off the inlet nozzle and can casue a leak when the washer is filling up.
Also, carefully run your hand around the bellows gasket to see if you can find any small holes that cold be letting water leak out. You'll need a flashlight to make this easier. It is hardly ever the hinges that causes a leak since the hinges are mounted outside of the door seal gasket (bellows gasket) and aren't ever exposed to the water.
Jul 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Miele 24 in. G865 Built-in Dishwasher Logo
98 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
