Question about Kenmore 75085 Air Conditioner
I have an ac unit that doesn't get cold does it need to be recharged
  • Kenmore Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 20, 2010
The aircon system on my B Class has been recharged but after about two months the cold air is not blowing.
recharged it but didn't fix the leak
take it to an accredited ac specialist shop for a system check and fix
ac units do not need recharging unless there is a leak
Oct 27, 2016 | Cars & Trucks
Does the rear ac line have it own recharge system
No it doesn't. You'll have to add refrigerant. dual systems just take more.
Aug 31, 2014 | 2005 Dodge Durango
My 2003 VW Convertble AC unit is not blowing air as cold as it used to. The AC unit is working
Most likely yes it does need to be re-charged with refrigerant gas as this gas can leak over a long period of time
Many garages can re-charge the system for you
May 01, 2014 | 2003 Volkswagen New Beetle Convertible
The AC in my 2003 VW Convertible is not cooling enough. What can I do about it?
A recharge is the first thing to have done. The system will lose some gas over time. The service center should be able to check for leaks as well.
Heater
Ac needs to be recharged
May 23, 2013 | Cars & Trucks
2007 dodge nitro not blowing cold air
The AC compressor may need recharged, or repaired / replaced. A lot of times what happens is through the winter AC units aren't ran so the seals recieve no oil and dry out letting coolant escape. Sometimes you can get lucky and a recharge (which contains oil essential for your seals) will do it - if they are too dry however, you will need a new compressor. You can have your AC unit recharged at nearly any dealership except in the state of California. Hope this helps.
Mar 27, 2012 | 2007 Dodge Nitro R/T New Cars
I have a roof top ac unit Model #7333C886 and someone is telling me that it cannot be recharged. Is this true cause it seems to be working fine other than not getting real cold. It is an older model I know...
It is a closed system, which normally they don't require recharge. It can be done but it is more or equal expense as buying a new unit. A lot of times a real good cleaning by someone who knows how to do it properly is all that is needed in cases such as yours.
Aug 23, 2011 | Coleman Mach 15 Air Conditioner
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
Air doesn't get cold like it use to. I spray cleaned the unit and it didn't help. Can the unit be recharged? Goldstar model: GWHD6507R Thanks.
Hello, yes the unit can be recharged but you need to install a piercing valve on tje low side of the system to charge in the refrigerant here is a link to where you can buy piercing valves. http://www.globalindustrial.com/g/hvac/parts/ac_accessories/Supco-Acces-Valves
Jun 07, 2011 | Goldstar KG6000R Window Air Conditioner
Cool but not cold air from my ac system
It sounds simple enough that you need to recharge your A/C unit. They can stop functioning properly after winter's end especially if they were not used. You should be able to get a recharge kit from your local auto parts store. Your Suburban should use the newer R142a refrigerant.
Jun 09, 2009 | 2003 Chevrolet Suburban 1500
Kenmore 75085 Air Conditioner Logo
56 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
