Question about Craftsman 25cc Gas Line Trimmer
How to change the starting rope of weedwreker 32cc.
    President:
  • Craftsman Master
  • 1,545 Answers
I know this info isn't in the users manual and I haven't found a "repair"manual yet but there is probably something out there. Some disassembly will be required for you to reach the point where you can actually service the starter/recoil unit with new rope. Torx head screws are used exclusively on these units and some patience and diligence will get you to the recoil unit. Be forewarned if you do it yourself....there is some work involved removing items.
Posted on Aug 20, 2010
  • Roy Cagle
    Roy Cagle Aug 20, 2010
    If you go to www.searspartsdirect.com and enter your model info you can get parts diagrams and parts breakdowns with part numbers for this and you will see what all needs to be removed to access the rope pulley.
How to replace starter Rope
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
How to fix string starter recoil on small outdoor power equipment like...
How to Install Pull Start Recoil for Backpack Blower
Apr 10, 2016 | Troy-Bilt Tb4bp 32cc 4-stroke Gas Powered...
When I pull start rope on my Craftsman 32cc 4 cycle weedeater . . . engine does not turn over . . . when I let go of the rope and it retracts . . . what is wrong?
There are 2 dogs or fingers that expand out to grab the flywheel when the rope is pulled They are sticking and can not expand or slide out. Remove the recoil unit and free them up When the recoil unit is off pull the rope and watch the action
Jun 08, 2015 | Craftsman Garden
TB4BP won't pull
crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
Aug 26, 2012 | Troy-Bilt 32cc 4-Cycle Gas Backpack Blower...
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
Impeller removal
Since the impeller is mounted on the crankshaft and the crankshaft is part of the engine...you're going to have to hold the engine still while you remove it. Do this by removing the engine's spark plug...turning the engine to where the piston is down near bottom of cylynder and stick a length of clean, soft rope or cord in the cylinder. Then, when you try to take the impeller off, the piston will compress the rope into the head (not hurting anything) locking up the engine and allowing you to do the removal.
Jul 15, 2010 | Troy-Bilt 32cc 4Cycle Backpack Blower
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
Feb 20, 2010 | Craftsman Garden
Starter rope pulled out and wont retract on craftsman trimmer/edger 32cc convertible incredi-pull
remove the starter cover and try to wind the starter rope manuly. the rope may have to be replaced if worn or broke..
Oct 22, 2009 | Craftsman Garden
32cc Craftsman Brushwacker
You have to take the machine apart. The first thing is to separate the shaft from the engine. Then take off the shaft driver. There is a screw in the end. It takes a #15 TORX screwdriver. Once that is off, you have to spin off the clutch. To do that, hold the engine somehow and remove the clutch counter-clockwise. With that off, you can then remove the engine from the molding at the other end. The spool will be sitting on the rewind spring so BE CAREFUL. If the spring comes out it will be a big pain! Just lift the spool off, replace the rope and attach as the old one was. Now, you have the rope connected. Place the spool on the spring. Place the rope in the notch at the edge of the spool and slowly wind the spool on the spring. When you have it wound as far as you want, take the rope from the notch and into the spool. Allow the rope to rewind onto the spool. Put everything back as it was before you started and you have finished...Good luck...Lee
Sep 08, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
202 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
