Question about Dishwashers
GE dishwasher GLD6300 series will not start. Appears to be on delay (2h) start/reset does not cancel it and it isn't counting down in the window.
  • 1,073 Answers
Remov power to the machine for 5 min, try new cycle if not check the door switch if it checks good replace the control board
if either of the door switches checks open with the door closed replace the door switch
Posted on May 03, 2008
Ge dish washer will not start just installed
Do you have any lights working on the control console? If so, then you've got power; if not, then check your electrical outlet, and if you've got power there, check the wiring inside the junction box.
If you've got power (lights), make sure you don't have a delay time set. (If it says "1H" or "2H" or something, then you've got a time delay set, and you need to clear it by repeatedly pressing the DELAY button until it goes up to 12H and then resets back to a run time. Finally, if that's not it, then you may have a bad door switch - that's kind of a weakness in the new GE dishwashers.
Feb 15, 2015 | GE Dishwashers
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
Dishwasher ran all night still not finished. Error code 4H displaying.
Hi and welcome to FixYa. I am Kelly. The 4H is indicating your dishwasher is in the delayed wash start mode. Here is some information from Sears about what to do:
  • The number letter combination indicates that the dishwasher is in a "Delay Start" mode, as well as how many hours were set for the delay start.
  • The dishwasher will not start the wash until it reaches the delayed hour that it was set for. Example: 1H = 1 hour delay start, 2H = 2 hour delay start, etc.
    • To start the dishwasher immediately and not wait for the Delay Start time, cancel the "Delay Start" option, by pressing the Cancel button. Then program the cycle and options and press Start.
    • To start the dishwasher after the Delay time, select the cycle and options desired. Select the "Delay Start" option and on some dishwashers it requires, pressing the Start button.
    • Some dishwashers will display a countdown of the delay time on the display.
Note: Refer to the Owner's Manual or Use & Care Guide for specific instructions on using the "Delay Start" feature.
If you need more assistance we will need your exact model number in any of your future responses.
Thanks for choosing FixYa,
Jan 04, 2011 | Dishwashers
How do I cancel the delay start? Everytime I turn...
Hi Guest and welcome to Fixya, I don't think what you're describing is the delay start, but rather a problem with one of the heating component's and most likely the heater relay on the electronic control. Likely if you let the unit operate from that point of displaying "2H" it will run and run for several hours and not heat the water. You can confirm this by pulling out the control and visually inspecting the printed circuit side of the control. Look for a burnt solder on the opposite side of the largest relay ( black or orange retangular box ). That will confirm the heater relay is faulty and the control either needs to be replaced or repaired if you are capable of resoldering the board. Let me know what you find and I'll try and assist you further if you require any. Thanks for visiting "fixya" today and good luck moving forward. Macmarkus :)
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Electrolux dishwasher delays before starting
  1. To cancel the the delay pad again when the delay is counting down. The indicator light will go out and the cycle will start or resume immediately.
  2. To cancel the delay and the cycle, press Start/cancel once to drain and turn-off the dishwasher.
  3. Press Start/cancel twice to turn-off the dishwasher without draining.
Aug 31, 2009 | Electrolux EDW5505ESS Built-in Dishwasher
Can not reset the ''delay cycle'' timer
I would call that service company back and ask for your money back first of all if he didn't fix the problem. That code probably means a failed circuit board.
Mar 14, 2009 | Dishwashers
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Time delay
1.Position the rotary switch to reset.
2.Press the RH button, with the clockface on it, once for every hour of delay required. The display will change to 1H, 2H etc.
3. reposition the rotary switch to the number of the required program.
4.Washer will start program after the selected number of hours.
NB. If you select too many hours, cotinue to press button as display will count up to a maximum of 24H before retuning to zero again.
Jan 24, 2008 | Indesit 24 in. DE73 Evolution...
Bosch Dishwasher, SHU 5300 - Cycle stuck on 2H cycle
yes it needs a new control and its pretty easy to replace..
Dec 13, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwashers Logo
301 people viewed this question
Top Dishwashers Experts
