Question about Philips Audio Players & Recorders
Dvd player is not working of philips hts3450.....can we replace the dvd only
  • 490 Answers
Howdy. When the DVD portion of a home theater setup fails it is usually simply not cost effective to have it repaired. An inexpensive solution is to buy a DVD player or recorder and stack it on the old one. This costs from 40 to 90 dollars and has you back in your seat the fastest.
Posted on Aug 20, 2010
Hi my philips hometheater HTS3450 subwoofer power supply is blown off and the philips guys are giving estimate of 100$. my question is if i dont want to use the subwoofer and the speakers but only connect...
yes.modern TVs have good speakers,and the bravia has a good set,with adjustable sound fields,plus a decent amp in them.just use good cables,and use component video cables,or HDMI if yr DVD has it.most have 1080 video resolution nowadays
Jul 01, 2010 | Philips HTS3450 System
When turn the system on freezes on "disc" then nothing works
Replace the dvd player with a HTS 3450 dvd player from ebay. Average price is $20-$30.
Feb 05, 2010 | Philips HTS3450 System
Philips HTS3450, sound cutting on and off during DVD playback?
If the Video portion of the DVD is running smoothly and the audio is cutting out, you've got an internal problem. You can try running a Laser Lens cleaner thru it, you can get them at just about any retail store, get one that uses fluid, 15-20. Good maintanance habit, run it thru a couple times then try a DVD. If it still has an issue, it's more cost effective to replace it than repair it, a repair would run 100-150 on average. Hope this helps
Jun 23, 2009 | Philips HTS3450 System
HTS3450/37 DVD player won't spin up to speed.
That is a common symptom of a depected Ribbon connector,you better replace it with identical rating in order to works normal again..
Hope it may helps you;;
Jun 08, 2009 | Philips HTS3450 System
I own an hts3450 system, dvd player part is destroyed.
You can check on ebay if maybe somebody else has damaged set. they seem to be sold a lot there. Otherwise contact philips vendor
Feb 10, 2009 | Philips HTS3450 System
HTS3450 from Phillips, have video but no audio
I have been quite involved with a sound problem in my HTS3450 (search for the topic "sound in only 3 channels"), and I learned that when you are in the setup menu the speaker volume will be greyed out if there is a disc in the tray...remove the disc, wait for the "disc loading" dialogue to switch to "no disc", the try accessing the setup menu again. Other than that I have no advise if you once had proper function after moving the system. Check out my experiences with the cable connecting the sub to the DVD/receiver in my postings. Good luck. Steve
Jan 03, 2009 | Philips HTS3450 System
Philips hts 3450 home theatre system, dvd in player, won't come
Before you do what I am about to suggest, understand that doing so will void your warranty with Philips. Find out if the product is still in warranty before proceeding - if it IS in warranty, then get it replaced through Philips (even though it is a simple solution):
Unscrew the four main screws on the bottom of the main base that are keeping the main unit together. Open up the case, retrieve the disc. Make sure that you do not knock ANYTHING out of place - you must proceed VERY carefully. Rescrew the case. Voila!
-Tha Mp3 Doctor
Dec 10, 2008 | Philips HTS3450 System
Region free
Sorry - every Philips model has a region it was marketed for, and dvd's from other regions will not work without an illegal hack (if one exists).
Dec 07, 2007 | Philips HTS3450 System
No sound on my PhilipsDVP642/37 DVD Player
there's a 6.3 amp fuse in the subwoofer that can be replaced.
Nov 11, 2007 | Philips HTS3450 System
211 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
