Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
How much will it cost to replace a timer on a washer repair and labor?
Timer inop
Can u tell me what part you need to replace so that i can tell u the cost and from where to get it..
Feb 09, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Should I chuck out the cooker because the oven timer does not work?
Believe or not a lot of consumer items are this way nowadays. It sorta like push mowers where the repair parts, shipping, and labor cost as much as a replacement mower. It so expensive just get parts in from China and other places for the items they are just dumping on us that it is more cost effective to just to replace items that are out of warranty.
Oct 16, 2014 | Ovens
My Kenmore 11020022012 washer stops prior to spinning cycle. If I manually turn the dial to spin, it will spin fine. Need help troubleshooting..
timer needs new electric motor to advance from rinse to spin cycle.
or alternately ,you can have your old timer taken out of your washer and sent out to be rebuilt or buy a new timer.
in any case , you will need a kenmore washing machine repairman to take out your old timer and send it away to be rebuilt and expect that to take 2 or 3 weeks
the timer rebuild used to cost$ 50.00 in 1993 and a new timer went for $110.00 to $129.00
for a sevice man to take out and reinstall a timer $60.00 to 100.00 labor
try to google.com or bing.com or ask.com-----and type in : kenmore washing machine,rebuilt timer. you will need the model number of the washer as well as the model number of the timer and the timer may have a different name that kenmore
also try typing in kenmore washer,new replacement timer
try call sears and see how much their service man wants to put in a new timer. I am sure prices have gone up since 1993
when I retired from the major appliance repair busness. i could do the timer remove & install, but I probably live 1000 miles from you.
another option: knowing that you will need to spend around $200.00 or more by the time you get a new timer installed
you might want to see how much lowes or home depot wants for their cheapest bottom of the line washer. that might be a good alternative as it allows you to get a new washer and buy an extended warantee so you dont get stuck with another 200.00 repair. I think they have washers starting at 289.95 only 90.00 morte that repairing your old washer which is going to run for how many more years before it again gives you trouble?
check out lowest prices on bottom of the line washers unelse you want to spend a lot on a fancy washer to make yourself happy.
you can shop on line by just google.com or bing.com and the name of the store. home depot, lowes, sears,walmart
and type in clothes washers.
Oct 08, 2013 | Kenmore Washing Machines
Washer will not cycle
Your unit's timer is going out on your. Contact a professional for a labor estimate. The part should cost around $60.
Jul 29, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Maytag Washer Model LAT9416AAE - Top tub seal is leaking or where the tub and the shaft meet is leaking. What would the cost be for parts and repair (service fees, labor, etc.)?
The usual charge when i have repaired that is around $375
in addation to the seal a tub bearing would be required since the seal has leaked it very likely has rusted the bearing. To replace those both the inner and outer tub have to come apart,the breakdown would be
Parts--$150
Service Fee $75
Labor $100
labor and service fees vary from company to company and that is probably low,yet it is a great washer and may be well worth investing in to repair
Aug 06, 2011 | Maytag LAT3600A Top Load Washer
I have a washer machine wirpool and dasnt change to the cicle spine
If your timer goes normally until it hits the spin cycle then it is your clutch on your motor. If your timer stops during a cycle then it is timer. Either way this problem should be able to fix around $150 to $200 depending on labor costs.
Apr 15, 2011 | Washing Machines
Washer does not spin and it makes a grinding sound
Hello keri... when it will not spin and it makes a grinding sound the transmission has gone bad. This is a costly part and a costly labor fee. Unless the machine is still under warranty a replacement is recommended over a repair. Joe
Thanks for choosing Fixya!
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My daughter wanted to run the timer on the microwave but accidentally ran the oven for 16 minutes. It overheated and blew out. Can this be repaired?
Your can be repaired, but it's generally not worth the cost. Running the oven empty usually destroys the magnetron tube which generates the microwaves. The tube is replaceable, but it's a costly part. And the repair should be done by a professional because of safety concerns. Between the cost of parts and labor, it's usually not much more (and sometimes even less!) expensive to buy a new oven.
While the kitchen timer feature of a microwave is handy, many people accidentally kill their ovens this way. You might want to pick up a small digital timer when you shop for a new oven. It's cheap insurance.
Jan 09, 2011 | KitchenAid Microwave Ovens
Re: Kenmore model 23032 - When washing a load that is on the heavier side (for example 5 bath size towels) the basket does not spin, but the motor runs and the timer works fine. I opened the lid and...
This is usually caused by the motor coupler. This is very inexpensive and easy to replace. Here is a video this will walk you thru this disassembling and replacing a motor coupler in a direct drive machine. It may be a different model but the troubleshooting and replacement will be the same. You can also enter your model # for your specific model to get diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Cost depends on your area, in upstate NY we charge $60 labor plus a $45 service call charge plus the cost of the part about $125 total.
Nov 05, 2010 | Kenmore 2303x Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
338 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
