Question about GE Refrigerators
Ge refrigarator mdl # gts22kbmbrww won't get cold
3 Suggested Answers
  • 52 Answers
SOURCE: where is filter on my ge model tbx25z?
Never seen one with a filter, sounds like you have may have a problem with the cold control. Also could possibly be where the settings on the control knobs are. Put both on 4
Posted on Jul 15, 2009
  • 11 Answers
SOURCE: my ge GTS22KBMBRWW refrigerator freezer won't stay
If you (or someone you know is competent at soldering, you may be able to fix this without a pro (nor replacement part).
At the rear of the fridge is a metal panel at top left behind which is the motherboard. If the problem is intermittent - e.g., slamming the door yields a loud 'click' and you hear the compressor start, chances are great that the problem is a bad solder joint on the relay that switches between defrost and compressor modes. (It seems to default to defrost mode.)
Unplug the fridge!
Remove the metal panel. (1/4" hex wrench or socket set req'd.)
Gently and carefully (wiggle and) remove all molex connectors from the circuit board. (There'll be 5 or more, possibly depending upon how many extra features your fridge model has.)
Use a suitable tool - needle nose pliers or strong tweezers - to squeeze the plastic stand-offs with which the board is mounted to the fridge.
Remove the board from the fridge. (Note: it may be easier to remove the connectors at the right of the board AFTER the board is lifted off the stand-offs.)
Look at the solder-side of the board.
You'll almost certainly see charring around a particular solder joint that belongs to the large, sort of T-shaped relay (black box) on the board.
Clean up the carbon with alcohol.
Scrape away some of the (green) coating on the copper trace around the pin that comes throught the board from the relay. (This will entail removing some of the acrylic clear coat with which the board has been sealed.)
Resolder the joint.
Clean up any flux residue.
Reinstall the board - right-hand connectors first, if necessary (i.e., before mounting the board on the stand-offs).
Replace the metal panel.
Plug the fridge in.
Listen to that relaxing buzz of relief...(and $100-$200 savings).
CAUTIONS: 1) Make sure you NOTE and/or remember which connector goes where on the board BEFORE you remove it.
2) If the room is dry enough that you're getting static shocks when you walk across the carpet, you might want to make sure you discharge yourself (say, on the kitchen sink faucet) before you remove/handle the circuit board.
Posted on Jan 08, 2011
GE refrigarator ice and water
Looks good to me! What is the model number? I thought I was going to get a demo! Sea Breeze
Apr 26, 2013 | Refrigerators
The back wall of my hotpoint freezer/refrigarator is frosting up what is wrong whit it.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Refrigerator won't stay cold on a kenmore 106.71182100
Refigerators work by absorbing the heat from inside and extracting it to the outside. This is acomplished through the coils found inside and outside. Make sure nothing is blocking the inside vents. Make sure you have enough ventilation behind and under the refrigerator. Clean the coils with a vacuum. They are either found in the rear or on the bottom of the refrigarator. Good luck!
Aug 04, 2011 | Refrigerators
Are there any refrigaration or electrical components in the side walls of a GE Profile 21cuft refrigarator? Model TBX22PAYGRWW I want to convert it to a kegerator
it could have hot gas refrigeration lines in it. drill a small hole and poke around untill your sure, then drill the size you need.
Apr 17, 2011 | GE Refrigerators
GE side by side refrigarator stoped getting cold. Has done that before but usually starts working in a day on it's own, but this time does not want to work again. Two and half year old. Asked a repairman...
when you find the timer you will see what looks like a screw....use a flat screw driver to turn it (it will turn only one way)turn it 1/2 turn if it will not start or hum replace the timer if you hear just a hum get a hard start kit for the compressor(it comes with instructions)
Aug 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is filter on my ge model tbx25z?
Jul 14, 2009 | Dometic RM2852 Refrigerator
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Freezer and refrigarator are not getting cold enough
maybe thats why they sold it??? you could try changing the ther,ostat to see if that dosent help
Nov 16, 2008 | GE Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
