Question about Intermatic & Self-Adjusting Wall Switch Timer
Need instructions/manual on how to set an Intermatic ST01C Timer
  • 760 Answers
I have an Intermatic E1600 Digital Wall Timer and I cannot remember how to reset it to an earlier time...and I have misplaced the instruction manual. Any help you can give me is appreciated! Steve
You probably have Intermatic Ei600 which is 5-year warranty timer that uses CR2 battery, and has same programming steps as lighter-weight Intermatic ST01C timer.
Open following links to identify timer, read ez set instructions, and download manual.
http://waterheatertimer.org/pdf/Intermatic-ei600c-manual.pdf
http://waterheatertimer.org/ST01C-program.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
The timing programs for Ei600 and ST01C timers remain in memory indefinitely even if battery goes dead. If you re-program current time and date, the original programs are still there.
If timer stopped functioning, then replace battery. Usually with battery replacement, the timer must be re-set which clears all programming.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Intermatic EI600LAC Electronic Timer
Need to know how to program it. just purchased a home with one and need to be able to program it. Can I down load instructions?
1) Question posted under Intermatic ST01C battery-operated timer.
2) If you have different timer, then add a comment with description of timer buttons for possible identification of timer and manual.
3) Open following link for ST01C manual, instructions with illustrations, wiring diagrams, and battery information:
4) Take a moment and rate answer:
Sep 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I misplaced my instructions for my timer and need to re-set it after a power outage. Can you please send me the instructions? Thanks.
Question posted under Intermatic ST01C, but Timer is not 100% identified since ST01C is battery powered, and should not lose programming or stop working with ordinary power outage.
Most digital timers have a battery or capacitor back-up for power outage.
Add a comment with description of timer buttons, or open link below to see most brands of in-wall timer.
Open following link for to identify Intermatic ST01C and Ei600 and download instructions:
http://waterheatertimer.org/ST01C-program.html#battery
ST01C timer has a battery backup. Power outage will NOT cause battery-powered display to fail, but power outage and power surge can cause any electronic timer to fail.
So either the battery went dead, or power surge ruined timer, or you don't have ST01C timer.
If ST01c display is not showing, then replace battery and then reprogram current time -or- manually re-set timer and then reprogram timer.
Sep 03, 2011 | Intermatic Inc. ST01C Digital In-Wall...
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
I need to find instructions on how to reprogram an Intermatic indoor wall timer.
You posted under ST01C Intermatic battery operated timer.
If you have different timer, then add a comment.
Let's review ST01C timer for a moment.
Programming will stay inside timer memory indefinitely until timer no longer works.
Even if battery is removed, programs remain. Current time setting does not remain in memory.
If battery goes dead, then current time will disappear, but programs remain forever.
If previous programming was correct, you might only need to set current time,.
In that case, you do not want to 'reset' timer and clear memory.
If you want to clear old programming entirely, then you can 'reset' timer using following instructions.
Press and hold on-off button, and then use paper clip to push in reset button for 3 seconds.
Release reset button but keep holding on-off button until INIT displays momentarily.
Release on-off button.
If display does not show, then timer battery is bad, or timer is bad.
For instructions how to set current time, click link below.
In addition to current time, the link has ST01C manual and also has EZ to follow instructions and photos for setting on-off times (but not astro times)
Instructions are different for astro dawn to dusk.
Add a comment at any time if you need free help with specific steps in the manual.
If you do not want to read the manual or open a link and read the steps or add a comment for further free help, then you can pay a fixya expert for phone support and that person will walk you through the steps while on the phone.
Keep in mind that ST01C timer has 1 year limited warranty, and your timer might be broken.
In that case you should try the free steps first.
Dec 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
How do I get a program instruction sheet?
Intermatic posts their manuals:
Link below goes to ST01C
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
If you have a different brand timer, add a comment and I will likely have the manual
-or-
View the timers on link below to find your specific product and the manual
Nov 11, 2010 | Intermatic Inc. ST01C Digital In-Wall...
If you keep hitting the program button after making sure no program events are set, it just keeps cycling back through the 1-7 day program event options.
The ST01C programming is long and hard to understand
Intermatic has posted a EZ-version for programming
First of all, you have to set current date on all brands of programmable timers before programming. On some timers, the wiring has to be correct before the timer will let you program.
If you have the ST01C, push the reset button with a paper clip until time flashes to 12:00, and then start over
When I have a problem with a timer, I go back to the manual and start writing out the instructions.
If you can write the instructions, then they usually make better sense >>> and then you wonder who wrote the manual.
Finally, the ST01C, and most digital timers, come with a 1-year limited warranty >> timers go bad.
Oct 19, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic & Self-Adjusting Wall Switch Timer  Logo
150 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
