Question about Matsonic MS8127C (MBMS8127C) Motherboard
Conecting the front usbs
Where do the cable connections go on the mother board for the front usbs
  • 1,342 Answers
Consult your user's manual.
Posted on May 03, 2008
Dear i have problem in my frent panel cuble... can you tell me where i put these cuble
On the mother board 3 plug in connecters are there
Front Audio
You can connect the front pannel cable accordingly.
Apr 28, 2011 | Intel Motherboard
How to connect front usb to motherboard
First need to check front usb cable attached on mother board usb plug or not if its not attached so plug in to this pannel and then after you can access it.
May 09, 2010 | ASUS P5PE-VM Motherboard
How do i replace fan acer 5739g
1.first remove battery and adopter.remove back side covers,wireless lan antenna
2. remove all the screws in bottom side.
3.just above the keboard ,the front panel neds to removed with little preasure from fingers and remove the flat cable jently. remove lcd panel cable,pull out wlan cable in upword direction.
4.un-screw screws over keyboard and lift the keyboard,look at the bottom remove the flat cable(the brown colored lock should be pushed up jently.
5.remove the touch-pad flat cable similarly & remove
any other cables
6.jently pull the top panel towards you with fingers( observr any cables/wires conected to mother board)
7.once front panel is removed remove other cables /wires connected to usb/phone socket/wlan.
8.un-screw the screws with arrow indicater to remove mother board from back panel.
9. remove the screws form heat sink attached fan jently.
replace the fan or heat sink with fan of the same part number.( a.  put few drops of any oil betwen gap pan blade and plastic it might clear dust    b. in case fan is smooth then 5 volts wont be comming from mother board(red wire) then u requir proffesional help ).
10. follow the reverse procedure to assemble the laptop.
*****before you start any work ground ur body start with bare foot as all devices are esd sensitive. try with your own risk iam not responsible for consiquential
damage to device/person .these are just hints to help*****
Mar 11, 2010 | Computers & Internet
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
for connecting these sw
just see on mother board there you see nearabout 16 pins on right hand bottem of mother board
there you have an integation of connectorfrom right hand corner i.e 1-3 for reset sw, 2-4 for power sw and last switches for front usb and audio
if you have p-3 then you dont attech audio and usb cables on *********** board
Apr 07, 2009 | Computers & Internet
Usb cable
If you are talking about something like a front usb socket that's connected inside the PC then look at this picture as an example.
Just look on the motherboard for these connectors.
They are usually marked usb on the board.
Mar 22, 2008 | Intel Motherboard
Prescott 533 mother board power up conections to front switch
I am looking for the connection of the power button to the motherboard. Somebody plugged it out and thought it was a single plug. Now I sit with 5 plugs and do not know where to put them back and how to jump the reset.
Mar 08, 2008 | Computers & Internet
Dell optiplex gx260 mother board
It would be easier to order the cable and front panel board assy as one. easy on ebay.
I have worked on them for years and never bothered to trace them out. and dell doesn't post the pinout anywhere.
If you can't find one I can get it for you cheap.
Mar 02, 2008 | Intel Motherboard
Computers & Internet Logo
164 people viewed this question
Top Matsonic Computers & Internet Experts
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
