Question about Casio Parts Cash Register PC Desktop
Error code e94 - Casio Parts Cash Register PC Desktop
  • Casio Master
  • 1,780 Answers
This a Casio code. It means the printer cannot turn. Make sure nothing is jamming the printer.
Posted on Aug 21, 2010
I have an error code of E94 on my intex portable spa what does it mean?
If alarm code E94 is displayed on the control panel, it means the water temperature is too low. If alarm code E94 appears, unplug and plug back in the GFCI/RCD and test the GFCI/RCD to restart the system when the spa water temperature is higher than 39?F (4?C).
Jan 25, 2016 | Intex Pool & Spa
Model EWF1048W. Won't start. What does error e94 indicate?
E94 - Washing cycle configuration error.
Incongruence of configuration values at the switching on of the appliance. Check that all the connectors are inserted correctly.
Possible configuration error. Replace the circuit board.
Dado
Dec 12, 2015 | Electrolux Washing Machines
E94 errorwhat is this
google it loads of errors and answers there. just write e94 error in google search bar hope this helps.
Mar 22, 2013 | Casio Parts Cash Register PC Desktop
Electrolux time manager 7kg washing machine keeps stopping mid cycle and has an error code E94
E94 means: "Console control problem. Replace control board."
However fault codes are not absolutes. They simply tell a service person where to look for a problem. For example, if i was a service man and i had a control board like yours on the truck i would switch it out first to see if it solved the problem. If it did i would charge you for the part and labor and be on my way, even if it was just a loose wire or connector that was causing the problem. Or if i was a washer warranty rep and the machine was under warranty and you said you were getting an E94 fault code i'd ship you a control board and consider the problem solved.
I am not a service man or a warranty rep so my advice is to wiggle the wires going to the control board. Also, disconnect then reconnect any plastic conectors you see. Let me know.
Jan 30, 2013 | Electrolux Washing Machines
Sir good evening i have cash regester casio 160cr.Error code is e94 pls help how i can run my cash regester thanks.
I suggest you to reset your equipment.Here is how:
Remove AA batteries and unplug register from wall for 15 minutes.
Two more options;
Option #1:
To print the transaction details before clearing the journal memory:
VERY IMPORTANT: Do not interrupt once printing begins or the journal will not be cleared.
1. Make sure the paper is full in the register.
2. Turn to Z mode.
3. Hit the RC key until the screen displays "E94".
4. Hit Cash Amount Tender.
Once the printing is completed, the journal is cleared and the register is ready for use.
Option #2:
To clear the journal memory WITHOUT printing the transaction details:
1. Turn to Z mode
2. Hit RC key until the screen displays "E94 Clear"
3. Hit Cash Amount Tender
Nov 27, 2010 | Casio Parts Cash Register PC Desktop
On the screen there is a E94 error messagage on the Casio P260 cash register . How can I correct this error and reopen the cash register.
E94 is a printer error. Open the printer and make sure nothing is jammed in it.Remove the paper roll. Look for old pieces of paper stuck in the gears etc. ----------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-260 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
Jun 16, 2010 | Casio Parts Cash Register PC Desktop
Anyone know what error code e94 on a casio cr120b & how to fix
E94 errors - paper jam can be cleared by removing battery back-up and replacing them. The error appears to be retained in the memory.
Dec 15, 2008 | Casio Parts Cash Register PC Desktop
Error code E94 paper jam
I used compressed gas duster to clean the resgister and it worked. It is called Duster Destroyer and I got it at the Staples for $9.99
May 30, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
168 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
tomferryman
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
