Question about Dryers
THE DRYER CYCLES, BUT NOT ENOUGH HEAT TO DRY CLOTHING
  • 1,998 Answers
This could be due to a lint back up inside of your machine when is the last time you had or dlinted the inside of your dryer in anycase this should be done at least once per year lint is the actual killer of all dryers is this a gas or electirc dryer if it is a gas dryer you can also do an amp test to the leads going to the ignitor which should read 3.3 amps any lower and the dryer will not heat up in time causing the heat to be reduced if your dryer is electric then you could do continuity test on hi and low relays to see if these are functioning properly first check the lint inside your machine which would mean takeing the cover off opening up the machine removeing the back panel as well as the blower tube which is what your lint filter sits inside of.Please remember to rank how this opinion helpd in your appliance situation and if you have any other questions please message me back have a great day
rickead1
Posted on Aug 20, 2010
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
Jun 05, 2016 | Electrolux EIED55H Dryer
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
When we try to dry the clothing, the gas dryer will not heatup and the timer knob does not advance. It does this on all the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
It takes 2-3 full cycles to fully dry a small amount of clothing like theres not enough heat???
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Nov 04, 2010 | Roper Dryers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
My whirlpool ler8648pg dryer has heat but not enough to dry larger loads. Takes multiple cycles to dry. Does anyone have a solution? Thanks
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 24, 2010 | Whirlpool LER8648P Electric Dryer
Dryer is not heating enough to dry clothing. The problem started with the electric braker box switch triped i had to replace it, dryer would turn on but no blower, I took a look at it and found some...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
87gh
Dec 09, 2009 | Estate TGDS740JQ Gas Dryer
Not drying enough
usually not drying enough, follows the statement long dry times, 2 or 3 cycles to complete the dry,
inspect your vent exhaust, and the entire length of the vent
you may have some sort of restrcction slowing down the exhaust which will cause heavy cycles,
the heat backs up inot the machine, and causes false high heat
Oct 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag atlantis gas dry is not heating up its about 6 years old
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
