Question about Astra (ASTRAPRO) Espresso Machine
I have a small, single head manual astra machine that i only use a few times a year for catered coffee events. I got it out today and the steam wand and hot water wand both work, but there is no water coming through the head. The machine heated up normally, but not a drop comes out for espresso. Is there an easy fix so i can do my event?
  • Astra Master
  • 1,711 Answers
You can follow these istructions
http://www.fixya.com/support/r4431161-no_hot_water_from_coffee_tap_sometimes
In any case the your problem is goggled group head for dry coffee or the coffee pipping from scale deposits.
Posted on Aug 20, 2010
Coffee machine steam wand pressure issue
Good question. I have been surprised before today after checking the manual for various gadgets. There are thousands of manuals online which can be searched for if it is missing. We have a bench top water filter fitted. When you have one of those, the difference is so noticeable that you will only want drinking water from there
Feb 28, 2014 | Coffee Makers & Espresso Machines
Just bought the machine. Basically, the problem is that the steam wand goes of on its own (or as soon as I push the coffee button) and that I cannot turn the steam handle at all or do anything to stop...
Hi. Make sure all your buttons are off. (switches all facing the same direction). Then make sure the tap is turned off. Switch main power on. Then switch the coffee on. you should hear the pump start. usually loud at 1st, then it will get quiter as the water is pumped up through the group head. When water is pouring through the group head, switch off the coffee button. Now let it finish heating. If you can get to this stage, then everything is ok. If you cant get it to this stage then you have a problem with the machine. Most likely a themostat on the boiler. Darryn REPAIRER
Sep 22, 2011 | Rancilio Silvia Espresso Machine
My 5 year old Giotto has stopped working
The vent valve on the machine is stuck in the open position. Turn on the machine and open the steam wand until you hear a hiss or see small water bubbles from nozzle, let it steam out a little more then close wand, that should allow the machine to heat up correctly, then order a new vent valve for the machine.
May 03, 2010 | ECM Giotto Espresso Machine
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
The steam wand and hot water valve work fine. Can't get any water out of the group head to make espresso. Pump sounds like it is working but no water comes out.
The coffee group is equiped with a jet and jet filer which is probaly blocked from dirt or scale. Need to be removed and clean up. Consider that the coffe solenoid valve and shower are clean from any dry coffee
Oct 31, 2009 | Astra Mega I Automatic
Chrome flakes in steam unit of Saeco Digital Plus Espresso machin
Flush the boiler a few more times with cold water atleast 2 more full water tanks.
Jun 27, 2009 | Saeco Royal Digital Plus Coffee...
Automatic astra II pulls a few great shots then error light on
The error light usually comes on when there is no water flow through the group after about 5 - 10 seconds, indicating a clog of some sort. The fact that it happens after two shots, however could indicate an issue with the processor. The problem with the steam wand could also point to a clog situation, especially in the other wand is working. First, try running shots through the problem group with no grounds at all in the portafilter; Say five or six shots if you can to see if you get the error light. Look at the water flow in the process: The water should just pour out of the portafilter. If the water is running freely and you still get the error light, you are probably looking at a processor/sensor problem. If not, it may just be a restriction. Remove the screw from the middle of the group head (the diffuser), and remove the screen and the brass plate and check them for clogging. You really want to wait until the machine is cold before you do so as the parts will be extremely hot. As for the wand, try removing it, and check it for obstruction.
Nov 24, 2008 | Astra Mega II Espresso Machine
No water thru the group head
We were having the same problem and this worked for us, right from an insert that was included with the manual.
1. Fill tank with water
2. Remove the filter holder
3. open the steam tap
4. press the main switch and the coffee switch at the same time
5. close the steam tap as soon as water begins to flow
6. If after 30 sec. no water comes out repeat the operation.
7. when it starts, draw off 4 cups of water
This worked for us after we had about given up,
Jun 07, 2008 | Rancilio Silvia Espresso Machine
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Astra (ASTRAPRO) Espresso Machine Logo
99 people viewed this question
Top Astra Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ross Keen
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Astra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
