How to install a A4 tech PK 635 M web cam without using cd installer?
how to install a A4 tech PK 635 M web cam without using cd installer?coz ive lost it.
installer
installer
Send me clent pls
How do i instal my A4TECH without CD
Hi
you can download the driver from this link, it will give you instruction as well, just select the driver for your Operating system
A4TECH
pls dont forget to rate solution, thanks!!
SOURCE: install A4 tech PK635 M web cam without cd installer
This for Faith - Follow the link below and on thr left side just click on the driver. Just save it to some place you know where it is and then install it. It has everything that was on the cd. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be glad to assist you further. Thanks and have a good day.
http://a4tech.com/ennew/download%20driver.asp
Jeff
This is nazir. I have enclosed the link for your A4 tech PK 635M Web cam. Can you please try it out.
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/OTHER-SCANNERS/A4TECH-PK-635.shtml
v\:* {behavior:url(#default#VML);}
o\:* {behavior:url(#default#VML);}
w\:* {behavior:url(#default#VML);}
.shape {behavior:url(#default#VML);}
Normal
0
Go to this site and select your product and download your
driver for your webcam.
http://www.a4tech.com/ennew/downloads.asp
Use the quick product locator then select “Web Cameras”
Then under “Downloads,” in the drop down, “Select”
the model number.
Also when it asks you for your Windows Operating Systen, be
sure to select the right one.
Then after completing the download do this.
Disconnect the Camera from the USB port and reinstall
the CD or Downloaded softwareprogram. When the program asks you to
connect the camera to theUSB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with.
Just installing the cameraon your computer does not set it up to broadcast on
messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video
to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/)
set it up as follows:
The camera and audio should function properly. Yourfriends
and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html)
Hopethis helps. Bud
1. Go to: http://www.a4tech.com/ennew/downloads.asp
2. Under the"Downloads" section, you will find 2 fields. Click the arrow next tothe field labeled "SELECT" & choose "PK" from the drop-down menu.The second field will display "130MG". Click the arrow next to thisfield & select "635M" from the drop-down menu.
3. Click the "GO" button.
4.In the next page: in the orange side-bar to the left you will find yourweb cam model & 2 buttons. Click the button labelled "Driver ForPC". This will start the download of the installer for your web cam.
problem with the windows logo
HELOOO I LOST MY CD INSTALLER ON CAM
i lost my cd installer....help me so i can use my web cam
i lost my cd installer of my pk 635m. how can i install it without the cd installer?
I DONT HAVE the driver cd of A4 TECH P635 WEB CAM
PK-635 web cam
