Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
My cord gets hot is that normal? - Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
  • 490 Answers
Warm is normal for 12 amp appliances like most vacuums. Hot is not normal and you should have the unit serviced before any further use.
Posted on Aug 20, 2010
  • 20 Answers
No that is not normal your motor is pulling to much power
check your brush and cleaning it out
Why does my plug get extremely warm or hot?
Inside the wire, several strands of wire are broke. Heat is caused by less strands of wire that have to carry more current in amps. This is a safety and fire hazard. Cut the old plug off by cutting the cord about 2 inches away from the plug. Strip the wires carefully. Do not cut or break off any strands of wire. Install a new plug. Make sure you buy a round plug that has a round opening for your round cord. A lot of plugs are for flat type of cords only.
Oct 24, 2015 | Rainbow E series Canister Wet/Dry Vacuum
I have a Kenmore Upright Model # 11630412001 with a broken power cord
Normally, you would leave the current power connections attached and then line up or label the new cord lines with the old.
There should be a common ground, easy enough to dsitinguish.
A hot, normally black.
A return, normally white.
These may be swapped it the existing wire colors are.
Red = new black
Black = new white
Green or Blue = Green or bare.
I'm a bit surprised t read your post as the cord should have come with connection instructions if the replacement cord is different in color scheme from the old.
ALWAYS TAKE SAFETY PRECAUTIONS WHEN WORKING ON HOT LIVE POWER. NEVER MAKE CONNECTION CHANGES WHILE THE VACUUM IS PLUGGED IN.
IF AFTER YOU CONNECT THE NEW LINES, TEST THIS BY TURNING ON THE VACUUM AND TURNING IT OFF RIGHT AWAY. IF YOU HAVE POPPED A BREAKER OR SEEN BURNING, YOU HAVE TO SWITCH THE BLACK AND WHITE WIRES.
The best thing is to always go online and find the wiring layout for you model.
If you have any doubt, pleast post the wire colors you do see now coming to the connection terminal and post the colors coming out of your new power cord.
Regards,
Worldvet
Jul 05, 2008 | Kenmore 35912 / 35913 Progressive Upright...
Why does the plug get hot when the heater is on
Sometimes the electric cord isn't made to handle the wattage of your heater....either change the cord or use a heavier extension cord.
Nov 16, 2014 | Vacuums
My shark professional steamer plug gets extremely hot. Is that normal?
no it should not get hot undo the plug and check if the wirers are conected tight one of the main causes is loose wires, have you tried a differant outlet.
Jan 22, 2013 | Vacuums
Why is it important that the resistance of an extension cord be small when it is used to power an electric heater?
Hi pipay thinti...
You must have little resistance (large wire) in the electrical cord because you want the elements of the heater to heat up and not the cord...if you had high resistance in the cord it would get too hot and melt the plastic coatings.
Please take time to rate me
Jul 26, 2011 | Vacuums
Vacuum getting hot in filter area
That's not abnormal, unless it's getting very hot. Have you changed the filter recently? If the filter is blocked it will get hotter than normal. the filter should be changed every 4 to six weeks of normal usage.
Apr 06, 2010 | Euro-Pro Shark Professional Upright Vacuum...
My Oreck XL has worked very well until the power cord was pulled out of it. I figured how to hook up the hot but can not figure out the neutral connection. any ideas?
if there are two wires it doesnt matter normally white 2 white and black 2 black if its 3 wire than green is ground and the other 2 dont matter thanks Don
Oct 31, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Lead gets hot
Check the cord for damage.
Oct 04, 2009 | Vacuums
Dyson 07 plug gets very hot after prolonged vacuuming
Electrical current passes through the electric cord and plug - it will get warm, that's normal. If the problem is worse where you smell an electrical burning smell, only an authorized dealer can fit a new power cord to your vacuum cleaner. Call the Dyson helpline, they will let you know who the closest repair dealer in your area is.
Jul 05, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hot cord
likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Sep 06, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
374 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
