Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 10 year old Craftsman tractor (18.5HP, 6-speed, 42" deck). For several months the right side of the deck will not cut right (leaves the grass much higher - almost uncut). We have checked the usual things (deck is level, spindle is good, newer belt is tight, blades are sharp and on correctly). My guy is stumped. Any ideas? ThanX Rick
  • 20 Answers
Check the rist pin above the blades my be bad and not letting
blade turn on load top spin but blad not turning
Posted on Aug 20, 2010
Testimonial: "Great suggestion!"
  • 4 more comments
  • rpeabody48 Aug 23, 2010
    My tractor guy (who is as stumped as I am) says this deck does not have wrist pins, just mandrells and bearings..
  • 490 Answers
You seem to have eliminated all the likely culprits alright, but your description does match the behavior of an upside-down blade.
Craftsman 18.5 over head valve can,t reach cutting mode speed or rpms. replaced carburater, cost at 110.00 dal,what could it be? do i have too shoot it with my 12 gauge shootgun?
Posted on Aug 23, 2010
    The engine is running fine and can actually run faster than necessary. This tractor cut perfectly for 3 years and then started doing this for no reason last season.
Wizard 42" (Craftsman) lawn tractor transmision locked. Belt smokes. 6 speed transaxle
if the trany is locked up u will have to remove the trany
most the time its the needle bearings on the input shaft
there 10-15$ each takes 2
but trany has to come aparts
they are fairly easy to open n fix them
Sep 14, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 inch mower cuts uneven, what is the problem?
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Jun 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed My mower is a 42 cut and leave a row in the middle of the cut
SOUNDS LIKE YOU HAVE A BENT BLADE TRY PUTING A 2X4 UNDER THE DECK THEN LOWER IT TO HOW IT LOOKS IF ITS THE SAME ON BOTH SIDES THAN YOR BLADE IT BENT
Sep 30, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 19hp craftsman 42 deck. It has two blades. It does not cut the grass in the center. It leaves a strip uncut. What adjustment should I do
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Sep 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Having trouble replacing a 42 craftsman riding mower belt...help Ithe old one broke off but the new one it on too tight...the replacement one is the right lenght help please
do you remember the routing of the belt? there should be a diagram on the deck somewhere - best thing to do is rout the belt while the deck is lowered, leaving the loop at the front to put around drive pully on bottom of engine. once that is all hooked up, there are deck adjusters on either side of the deck - that you can adjust to relieve some of the tension on the belt - turn the adjusters clockwise to tighten, counterclockwise to loosen - let me know if this helps or if u need more info - i have a 10 year old 42" deck tractor out in my barn and if need be, tomorrow i will walk u through - online how to adjust the deck
Sep 06, 2009 | Craftsman Garden
One blade on deck gives an uneven cut
Sounds like a bent shaft, or the mounting is not flush.
Jul 04, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Sep 03, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
243 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
