Question about Pioneer DEH-1100 CD Player
I have a pioneer multi cd hooked to a pioneer deh 4700mp when it wsa wired someone else wired it they wired hot from multi cd to ignition it shoulda been hooked to something always hot i am trying to figure out where to hook hot wire its n a 2001 chevy silverado it started out as a fm mod but was changed to pioneer head thanks
    Guru:
  • 642 Answers
Connections to the rear of the unit. RCA connectors are for output to amp(if fitted).
Main connector:
Yellow - To be connected to supply that is always "hot" irrespective of ignition position. This is for memory backup. If you cant find the original wire on the car it is recommended that you fit a new one straight from the battery. Be sure to use an inline fuse(15A) as close to the battery as possible. On the harness leading to ignition will be a thick white wire which will ne "always hot". It can be safely wired to this point as well
Red - To be connected to power from ignition. This line should power up and down with ignition operation. Red and yellow can be connected together and then to an "always hot" line. You will be able to use the radio with the ignition off, but forget the radio on and you have a flat battery the next morning.
Black - To earting point or negative of battery.
Blue - To auto antenna relay and/or amp power control. Do not connect directly to auto antenna. Always use a relay. Have a look at the following link if you're not sure about relay wiring : http://www.fixya.com/cars/r5544622-wire_relay
Yellow/black - Equipment using an auto mute function ie handsfree cellphone kit is wired here.
Speaker connections:
White - Front left positive
White/Black - Front left negative
Gray - Front right positive
Gray/black - Front right negative
Green - Rear left positive
Green/black - Rear left negative
Violet - Rear right positive
Violetblack - Rear right negative
Posted on Aug 20, 2010
  • Rene Rossouw
    Rene Rossouw Aug 21, 2010
    On the CD changer connect the black connector of the bus cable to the CD and the blue connector to the head unit(radio). The small black wire can be connected to the vehicle bodywork. The yellow can be fed to the radio and connected on the same line as the radio's yellow. Always set the angle switch so that the slot is horizontal.
Pioneer radio wont retain station memory
clock probably doesn't stay either.....sounds likke the wiring may be incorrect...there are 2 battery + leads on these radios...One is yellow...which should be hooked up to a hot lead that is hot all the time even with the key off( you could just run a wire to the positive side of the battery)..thios lead is the memory lead that keeps stations, settings, and the clock....then there is the red lead that is supposed to be hooked up to a switched positive lead...such as the accessory lead fron the ignition switch....it's a good bet that the red and yellow leads are hooked together and that they are hooked to a switched ignition lead right now...all you have to do is disconnect the yellow lead from where is hooked now and hook it to a hot all the time then your memory, and stations should be retained
May 10, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
I need a wiring diagram for a pioneer deh-p6400.. please help..
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
I NEED WIRING DIAGRAM FOR PIONEER DEH-P470MP
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4700MP/index.html
the wiring diagram is on page 5 of the installation manual
Cheers!
Oct 11, 2009 | Pioneer DEH-4700MP CD Player
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Trying to figure out the wiring for and 85 chevy truck i have a pioneer deh p4800mp
the red on the player is acceley (hot when ignition is on) and the yellow is constent hot (hot all the time) and the black is ground but u can go to a radio shot or walmart and get a plug that wires to your stereo color to color and then plugs into the factory wiring harness
Oct 06, 2009 | Pioneer DEH-P4800MP CD Player
Lost memory
Car stereos typically have an "ignition" and a "battery" wire. The ignition wire is connected to your ignition switch, and only supplies power to the stereo when the car is turned on. The battery wire is connected directly to the battery, and always supplies electricity to the stereo -- even when the car is off. This maintains presets, clock, and other settings in your stereo.
It sounds like your battery wire was either not hooked up, or has come loose. On your stereo, a Pioneer, this wire is yellow. Locate the yellow wire on the wiring harness on the back of your stereo. This wire should be connected directly to your battery (or another source that gets constant +12VDC).
Sep 14, 2009 | Pioneer DEH-P3600 CD Player
Need a hot wire radio switched
The black wire is the chassis ground and should be hooked to an unpainted metal surface. The yellow wire should be hooked to a constant 12 volt line, one that is not controlled by the ignition switch.
You can find more installation information in the online installation manual.
Aug 20, 2009 | Pioneer DEH-P4000UB CD Player
I bought a car stereo but it wont save presets.
make sure you have the yellow fuse wire hooked up to bat. power (always hot) red wire is your ignition power
Nov 12, 2008 | Pioneer DEH-1600 CD Player
Pioneer car stereo-how to hook up speaker wires
ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
Oct 01, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Pioneer DEH-1100 CD Player Logo
47 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
