Question about LG Dishwashers
My LG dishwasher also has a hight pitched squeal while running. I see several posts on this but no answers to the question. What causes it and how to fix it?
  • 1,998 Answers
If your unit is less than 1 year old have LG come out and fix it.....If not your problem is going to be within the sump assembly....You would need to replace complete sump assembly...The assembly is very weakly made..</p>
i think that this is the same whislte that yr hearing please listen to this video that I am sending you http://www.youtube.com/watch?v=aAYhKacLEE4 they really dont make the sumps in these to last most of the time it would be cheaper to buy a sump with motor kit this way you get both pieces new if you buy either of these two pieces seperate you end up spending more money you can also order the kit directly from marcone appliance parts. please remember to rank how this post has helped in your appliance situation and if there is anything else i can do for you please message me back thankyou again and have a great day rickead1
Posted on Aug 20, 2010
  • frank mohr Nov 25, 2010
    MINE IS A LG 3850DD3006A AND YES THE GARBAGE DISPOSER GETS STRAWS AND JUNK IN IT. OR THE SCREEN ON THE TOP IS COVERED WITH MACARONI AND CHEESE. OR TWICE IN 4 YEARS THE MOTOR RING SPLIT AND THE MOTOR STARTED TO GRIND THAT RING TILL IT STOPPED ALLTOGETHER.
    WHAT A PEACE OF JUNK!!
    I ADMIT THE STRAWS ARE THE USERS FALT!
    SO MY NOISES ARE STRAWS, THE MOTOR, AND TOO MUTCH FOOD COVERING SCREEN IN BOTTOM NEAR SPLASHER BAR, OR ONCE IT WAS GARBAGE DISPOSER UNDER SINK THAT WAS CLOGED FROM NOT RUNING IT AND FOOD HAD BUILT UP INSIDE, BLOCKING DISHWASHER DRAIN HOSE.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My Whirlpool Quiet Partner II, Model #W10130986A makes a high-pitched squeal when filling, which varies in intensity when I turn the sink faucet off and on. What could this be caused by?
Sounds like a restricted water inlet valve on the dishwasher. Replacing the valve should solve it, if not there may be another issue with your house plumbing.
Oct 11, 2014 | Whirlpool Dishwashers
Lg 3850dd3006e makes noise
I had the same issue with my LG it has a stainless steel impeller the grinds up the food particles and if one of the veins get slightly bent it causes that problem. The tack took it out straightened it out until the new part arrived and it worked fine. He did return to replace it but I don't think it was needed
Jul 29, 2012 | LG 24 in. LDF 7811 Built-in Dishwasher
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dishes are not getting clean. There is a high pitched squealing noise when it runs. Its very hot inside when the cycle is done.
Hi - I dont do repairs for these mid range appliances - however I believe the problem is with the dirt caught in the jets and through the water reticulation.
Try - take the arms off top/bottom if applicable and run the machine and check your pressure from the pumps and have a nosy the if there ae any blockages of the jets as these will give the indications of the symptoms you have posted..
Good luck
Jun 21, 2011 | Westinghouse MDB631 RF Dishwasher
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
I hear a high pitch squeal some times when its running a normal cycle????
hair or wire or wrapped lint around the blades that grid the food. Had to dissassemble from inside the unit, pull out blade, remove hair, reassemble - really hard. Get the rubbers just right. It's a 30 min job yourself. just start pulling out all the screws around the bottom on the inside.
Oct 05, 2009 | LG LDF6810 Built-in Dishwasher
Dishwasher works great, but makes a high pitched squeal
This is usually a dry seal, will eventually leak, suggest exploritory surgery....
Sep 17, 2009 | LG LDS4821WW 24 in. Built-in Dishwasher
High pitched squeal
sounds like the water pump bearing might be defective. best advice is to replace the pump.
Jun 09, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
High pitched squeal
Hi...
Does the squeal come from the TV cabinet or the speaker?
If from the cabinet , it's most likely the Horizontal high-voltage section of the set.
Find someone that's good with hand tools,unplug the set from the wall outlet, let it sit for a good 30 minutes.
have someone open up the back of the set and dust out and vacuum out any dust from inside the set.
Put back together and try it out.
Jan 01, 2009 | Samsung TXN2034F 20" TV
Dishwashers Logo
1,576 people viewed this question
Top LG Dishwashers Experts
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
