Question about Sony Hi8 Hi-8 Tape
Reinsert cassette when I insert a tape, the screen flashes "reinsert cassette". So I guess the camera has a problem recognizing the tape. What might be wrong? Thanks. That really works thumbs up
  • moftah benshoob Oct 03, 2008
    when i insert the casset in digitel optical cammera recorder sony hi8 , then pushed
    down the cover and play the casset it dosnt work then disply error message( 3122, 3121/ reinsert casset)
    pleas sent to me on my Email :maintenace_electronic@yahoo.com
    my name is moftah ben shoob
    bengahzi-libya
    Novelist:
    Champion:
  • 236 Answers
Re-inserting in and out will temporarily make it work. switch contacts are bad and has to be serviced, cleaned otherwise replaced.
Posted on May 03, 2008
Not a problem recognizing the tape but a problem with the casette mecanism, swtiches. it has to be serviced and cleaned
How do you insert a video 8 cassette into the vhs cassette adaptor.
There's no way! They are two vastly different systems.
Video8 tape is nearly 1/4 inch wide whereas VHS tape is 1/2 inch wide - and thats just the begining!
Electronically, everything about them is different which is why Video8 came out from Sony in 1985 to improve on VHS systems and camcorder quality.
The higher quality version Hi8 followed in 1990 which made it's way into the professional market too.
I used the both formats for TV news and other programmes 1989-2000 when I went over to DVCAM, a professional compact cassette system also from Sony so I know the 8mm systems inside out.
Nov 20, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
My sony hi8 Handycam TRV 138 gives me a message reinsert tape What is wrong? do it need repair
The cassette is not being detected when the tray is landing. If the head is not spinning but you are getting the cassette ejected then it is a malfunction of the loading mechanism. Even if the tape end detection optocouplers are defective the fault could be so.If you can check this out then try and test the voltage before and after the cassette loads. there should be a change if not replace. check on the loading mechanism too. Hope this helps. Good day
Jun 28, 2010 | Sony Hi8 Cleaning Cassette / Head Cleaner...
My tape just quit working- it flashes an error message on my camcorder - it won't play. It has my daughters first year of life on it. Can you help me?
I think my Hi8 tape was magnatized I had 3/4 of the cassette taped I played it back once and when I went to play it back again I got a blue screen. I went to the local camera shop where we played the tape on his camera and we got intermitent static but no video. My canera is a Sony DCR-TRV260
May 19, 2010 | Samsung Hi8 MP Hi-8 Tape
I inserted a vhs-c tape in to my cassette adaptor and the motor started running but it won't stop. I tried to remove the vhs-c tape but the switch does not respond. I can put the cassette adaptor in the...
That may be what you will have to do, in this case, unless you can somehow get that switch to work. I don't understand why the motor continues to run, but it's probably a broken plastic piece or other gear part that's not functioning. When you take the cassette apart, try to look for any broken parts, or loose components that you can reseat. You may have to end up buying another adapter. Wish I knew more to tell you, but that's all I can think of.
Apr 18, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
I have a broken VHS cassette.
You can remove the 4 or 5 screws at the bottom of the tape, turn the tape over CAREFULLY pull the top off. If the tape pulled out of the end of 1 spool, you have to remove the clip in the tape hub, reinsert the tape and snap the clip back in. Holding the tape door open so as not to catch tape, put top back on and replace screws. Hope this helps.
Aug 08, 2009 | TDK T 120HS VHS Tape
CASSETTE ADAPTOR VW-TCA7E tab won't retract when I place the video camera cassette in the adaptor and close the cover. The triangle-shaped tab is on the left side of the adaptor and when it has not...
I had a similiar problem, or so I thought, but my son has just found that it needs a battery, which I did not even know, so maybe yours just needs a new battery? the cover is near the tab, hope this helps
Apr 20, 2009 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
Mini cassette tape is wrapped around one spool inside the casette
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
Nov 24, 2008 | Maxell 179030 Microcassette 3-Pack (60...
JVC VHS Cassette adapter C-P7u
How to safely open Micro MC_90 cassette
Oct 20, 2008 | Electronics - Others
Sony Camcorder tape P590HGD
YOu may be confusing HI8 with 8mm. One being analog,the other being digital, and a slight difference in form factor
Oct 20, 2007 | Sony P6-120MP 8mm Tape
Sony Hi8 Hi-8 Tape Logo
160 people viewed this question
Top Sony Electronics - Others Experts
laikexpert
laikexpert
Brian Sullivan
Brian Sullivan
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
