Question about Samsung Televison & Video
The picture on my tv has shifted upward and i can't seem to figure out what button to press on the remote to get it back to normal
    Brigadier General:
  • 5,158 Answers
Perhaps have a look to see if it is off channel 3 or 4. if not go into the menu it will be a vertical or horizontal setting. sometimes in the menu is an item to restore the picture to default settings.
Posted on Aug 20, 2010
Son got a hold of the remote and now the picture is larger and doesn't fit the screen- I don't know how to get it back to normal. Help!
hi,
your tvs zoom function is in on position. to make it of just press the picture size button on your tvs remote. every time press the picture size button different mode will seected, like zoom ,compression ,normal.
select the normal mode.
be sure that the selector switch in the side of the remote should be at TV
ok
Jan 27, 2011 | Toshiba 32HF73 32" TV
I have a sylvania flat screen tv when i get home tonite find out the kids have done something to the tv it seems they have zoomed it in but cant seem to figure what they did plus i cant find my book that...
They've probably changed the screen ratio from 4:3 to 16:9, or vice-versa. You didn't state which model of TV you have so I'm not sure which buttons you have on your remote, but there should be a button on your remote with "SCREEN MODE" or "SIZE" written on it. If you have this button try pressing it slowly but repeatedly until the picture size returns to normal or it says "AUTO".
If you don't have this button or can't get it to work, please post back with your TV model number and I will supply the correct instructions for returning your picture to the correct size.
BElectric
Dec 10, 2010 | Sylvania Televison & Video
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
I accidentally hit a button the remote near the
hello on the remote control it should say tv if you press it .it should take you back to normal view . or if you keep pressing that button and go through all the channels it should bring you back to normal tv
regards
shaun
Jan 20, 2010 | Televison & Video
Hello my picture seems to have shifted upwards ie the top of the image is now at the bottom of the screen then there is a black line then the next two thirds are above the black line. I think on an old tv...
The problem was not actually the tv the fault was on the satellite box. I unplugged the box from the mains to reset it and the picture was restored to normal.
Oct 06, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture stretched on samsung ws32z409t tv
Sometimes on a remote theirs a zoom button or HD zoom if you pressed that the tv will do what you describe if you press it again it will go back to normal view.
Jul 27, 2009 | Samsung WS32Z308P 32" TV
Ilo lcd tv..picture too large??
I had the same problem and tried everything with the tv to get it back to normal. I would look for what was suggested by tvtek, but also look on your cable remote or box for an "aspect" button. That fixed my problem. If your problem occurs with DVDs as well then you may have another issue, but if it is with cable only, try this. When I called our cable company the tech said alot of people this button without even knowing it.
Feb 26, 2008 | Televison & Video
My DVD playes only shows in black and white
Grab the manual and the remote, my guess here is you have accidentally changed regional setting, depending on where you live.
Some remote controls have a button, it's simply a matter of identifying the said button and pressing it again to change your regional setting back to it's original.
Jan 12, 2008 | Classic Electronics Classic DVD42S...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Remote control
I used a GE Universal remote. The package has number 24921 and the instruction manual says it's a RM24912. Anyway, this model will control pretty much all aspects of this tv combo assuming we are talking about the KLH KDT133UY tv/dvd.
What you need to do is program the tv button on the remote to code 0029 which is a KONKA code. The real maker of KLH electronics. Then set the dvd/vcr button to code 0905. Now in order to access the tv menu, press the tv button then press the shift button which is the setup button. Then press the INFO button for menu. SHIFT, MENU, OK, and EXIT are printed with a black backgroung on the remote. Hince you need to press shift.
Took a while to figure it out, but here you go. Good Luck!
Nov 20, 2007 | KLH KDT133UY 13 in. TV/DVD Combo
Televison & Video Logo
51 people viewed this question
Henry  Thomas
Henry Thomas
