Question about Hotpoint RGB745 Gas Kitchen Range
Control set blinks, clock will not reset, oven cannot work
  • 1,998 Answers
Replace the control board heres how u can check the control to assure it is the control take a multimeter and check for power going into the control board turn the oven on bake and follow the lead for power going to the bake element if your power is going into the control board but not leaving the board you would need a new control. please remember to rank how this post has helped in your appliance situation and if i can answer any other questions please message me back thank you again
rickead1
Posted on Aug 20, 2010
My clock is just blinking and my oven won't work wat would the problem be
many clocks blink when there has been a power outage . try resetting the clock . if that does not work it will require a repairman
Nov 10, 2016 | Ovens
After a power outage, the oven control light keeps flashing.
You have too reset clock pressing two buttons works for me
Nov 09, 2015 | Ovens
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
Re-set Clock due to power black out
Lucky for you(?) I had to reset our clock for daylight savings and checked here before i found my manual. If you're still looking for an answer, press the + & - buttons at the same time, let go and you have 4 seconds to press the + key again to set the time
Jan 28, 2009 | Magic Chef 9122 Gas Single Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
When oven is baking, control resets
theres a loose conection on the oven control more than likely its internal and youll need to replace the control but check you wirs to the control first just incase the bad conection is there. if its not, replace the oven control
Nov 24, 2007 | Whirlpool GS563LXS Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
142 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
