Question about Rowenta Irons
The iron heats but steams inconsistently. So frustrating to try to use the steam feature which is so unreliable. What is the cause?
  • 490 Answers
If anything other than distilled water is used, there will likely be a build-up of minerals in the interior of the iron. This can get bad enough to partially block the steam emitters. A CLR product that is designed to remove this build-up can be found at most hardware and grocery stores. I hope this helps:)
Posted on Aug 20, 2010
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
Issues with Rowenta Steam Iron DG 05030 steam hose
Does your iron have a self cleaning feature? It sounds to me like you have calcium build up and when you squeeze the hose it displaces the "clog" just enough to allow steam through.
Nov 12, 2012 | Rowenta Steam Generator DG050 Iron
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
It leaks water when I iron sometimes staining my clothes with black streaks or water stains.
Hello :
1:Clean your steam iron according to the manufacturer's instructions. Your iron is more likely to leak when it has not been cleaned properly. Plus, the water that leaks from a steam iron that hasn't been cleaned will likely be dirty and stain your fabric. Every steam iron brand is different, so be sure to check the manual that came with your iron or browse the manufacturer's website for instructions on keeping your steam iron in good working order.
2:Use your steam iron on a rigid surface like an ironing board. In a rush, you might be tempted to quickly iron a blouse or pants on the nearest available surface like a bed, carpet or even on a table with a towel draped over it. However, these surfaces may not provide the proper amount of level padding for successful steam ironing, and leaks are more likely to occur. Take the time to set up your ironing board for smooth steam ironing to reduce water leaks on a bumpy surface.
3:Allow your steam iron to heat fully in the upright position before ironing. Because your steam iron is designed to convert water into steam that will easily smooth out wrinkles on bulky fabrics, you can avoid leaks by ensuring your iron has time to get the water to the correct temperature. If you lay your steam iron in the horizontal position too quickly, water that is not hot enough to convert to steam will leak. Give the iron a chance to heat up, and then test your steam function on your ironing board cover or spare fabric swatch before tacking your favorite blouse.
4:Turn off the steam function on your iron when ironing at lower temperatures. Since your iron's steam function is designed to convert the water in your iron to steam at the right temperature, lower iron temperatures can cause water to leak if your steam setting is still activated. For ironing more delicate fabrics, turn off the steam to avoid water leaks.
PLEASE RATE !
Apr 18, 2010 | Euro-Pro Shark GI490 Iron
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Leaks water out all the time. Clothes wet or rust marked.
OMG, how frustrating to be ironing and water shoot out everywhere from this iron....So, to remedy it, I have turned off the steam, use it as a dry iron, and have a spray bottle handy to spray as I iron...love the feel of this iron, but hate the water everywhere...
Sep 02, 2009 | Euro-Pro Shark GI490 Iron
MY iron is less than 1 year old. It has been stored for about 3 months. Now when I tried to steam a garment with it, it does not steam unless I hold the steam button down. Otherwise nothing comes through...
Sounds like there was water in the line when it was stored, which caused deposits to bild up in the line and not work without pressure. Hence having to press the button to get steam out.
Try loading it full with really hot water and a small amount of bleach. Steam all of the water out of it into the air. Clean out the resevoir with fresh water after it has cooled and try again.
Please remember to rate this solution.
Feb 19, 2009 | Rowenta Professional DX8900 Iron
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Irons Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
