Question about GE WSXH208A Front Load Washer
My GE WSXH208V1WW Front loader wont drain and go through spin cycle. How do i troubleshoot this?
  • 3 Answers
SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
SOURCE: my ge front loader is making a banging noise while in spin cycle
When I was researching which washer to buy I read that this one is not the best choice to have on a second floor. Ours is on the main floor and can still be a little loud in the spin cycle. Have you balanced the machine properly? Otherwise, I think I read that people have had success putting a thick, dense rubber mat (like a stall mat for horses) under the washer to minimize the sound/wobbling. Good luck!
Patty
Posted on Feb 15, 2009
SOURCE: GE Front Loader Won't complete cycle
My GE Front Loader is 18M old and it has been progressively getting worse, not spinning the water out......I should have known the Pump had a cleanable strainer as Solution #1 says. Pulled a fist size chunk of wet lint, coins, a necklace and wrappers from the Strainer, not to mention about 2 Gal of dingy, soapy water. Tried a Drain/Spin and after a couple of minutes, went to High Speed Spin for the 1st time in about 3 months. Obviously there is a Water Sensor on the Drain Line somewhere that if the Drain Line still has water in it, it does not allow washer to go into Med/High Spin Mode.
Posted on Feb 17, 2009
  • 77 Answers
SOURCE: GE washer - Top loader wont spin, clicks
main board problem
Posted on Apr 26, 2009
  • 410 Answers
SOURCE: GE front loader does not go into final fast spin
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. It sounds like you may have a slipping (loose or stretched) v-belt. See if you can get the back off and look for a way to tighten the belt. This is a frequent problem. The built in a way to tighten the belt.
Posted on Nov 24, 2009
My front load GE washer is filling with water and draining but doesnt spin, exept for the first two spins when started
it isnt the door lock or it would not work on the first 2 spin cycles and unless you have huge out of balance loads the door(not lid as lids are only on top loaders) interlock probably isn't at fault. i would cleanout the tub to pump trap inspect the pump for blockage and flush the discharge hose. it doesn't cost a penny to do this and has fixed many front loaders with the same problem
Sep 30, 2011 | GE WCVH6260FWW
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washes partically drains.wont spin
if this is a front loader make sure you use he soap, or you may have a kinked drain hose
Mar 01, 2010 | Washing Machines
My ge front loader will not spin. the door is
My front load washer will not spin or the drum will not turn on the wash or spin cycle.
Dec 13, 2009 | GE WBVH6240F Front Load Washer
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Jan 14, 2009 | GE WSXH208A Front Load Washer
My font load washer wont fast spin or drain
gimme those older models anytime. their having a lot of trouboe with this front loaders
Jan 07, 2009 | GE WSXH208A Front Load Washer
Ge front loader washer wsxh208a
remove bottom cover and clean pump
Sep 07, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
69 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
