Since connecting my new c4200 series printer I keep getting a message "HP Digital Imaging Monitor has encountered a problem and needs to close. We are sorry for the inconvenience." Please tell Microsoft about this problem. I have already sent the message twice and nothing happens.
  • 537 Answers
Uninstall your HP software and reinstall. If that doesn't fix it, email or call HP and tell them more about your problem.
Posted on May 03, 2008
My HP Photosmart C4200 All-in-One won't scan. It keeps giving me a message, USB not connected but it is because I can copy and print. HELP!
do you have the correct drivers downloaded for scanning? go to this page <A href="http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&amp;h_lang=en&amp;h_client=s-s-r2515-1&amp;h_cc=us&amp;h_query=HP+Photosmart+C4200+All%2din%2dOne+Printer+series">http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&amp;h_lang=en&amp;h_client=s-s-r2515-1&amp;h_cc=us&amp;h_query=HP+Photosmart+C4200+All%2din%2dOne+Printer+series</A>&nbsp;and find your printer and go throught the diagnostics tool, it wil fix it for you
Aug 30, 2010 | Computers & Internet
Tip
How to Solve No Scan Options: Refer to device documentation to troubleshoot
How to Solve Cannot Scan Error or No Scan Options: Refer to device documentation to troubleshoot
1. Click Start ,
2. Click Run and type Msconfig and then click on ok
Will show the new screen of System configuration utility
3 Click on startup option
4. Search the list for HP Digital Imaging Monitor .
5. Select the HP Digital Imaging Monitor check box.
6. Click Apply , and then click Close .
7. Click Restart to restart the computer.
*Note : If HP Digital Imaging Monitor is not on the list,
it means the driver was not correctly installed.
You need to reinstall the software.
on Jan 22, 2010 | Office Equipment & Supplies
Please let know in hp0fficejet4355 how to scan and save in my laptop
On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality and result in the No Connection error message. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software.
After you have made the scan, you can find it using the Photosmart Software. It is also stored in the "My Scans" area under My Documents on your computer.
Jul 04, 2010 | HP Officejet 4355 All-In-One InkJet...
How do I use the scan feature on my HP Officejet J3680 All in One. I pressed the "scan" button and received message "No scan option, refer to device documentation to troubleshoot". I do not have "device...
The HP Digital Imaging Monitor (DIM) software must be running in order to scan from the printer.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor .If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software.
  8. Try scanning again
Regards,
Riztech
Jun 16, 2010 | HP J3680 Officejet All In One Printer
Hp officejet 7310 all-in-one software will not install
  1. Solution one: Make sure the hardware is functioning correctly(try to make a copy)
  2. Solution two: Restart both the All-in-One and the computer
    3. Solution three: Check if the correct scanning device is selected as default under HP Software
    4. Solution four: Download and run the Scan Diagnostic utility(FROM HP.COM)
    5. Solution five : Check that the Digital Imaging Monitor is running
    6. Solution five :Try scanning without HP Imaging software
    7.Solution six :Try scanning without HP Imaging software
Jan 26, 2009 | HP PSC 1410v All-in-One Printer
Scanning
"HP cue scanning flow component problem"
Run or double click on the "HPQDSCTC" file in:
C:\Program Files\Hewlett-Packard\Digital Imaging\Bin OR c:\Program Files\HP\Digital Imaging\Bin
This should resolve the issue and if the issue persists then completely uninstall and reinstall the software from HP's website.
Try this. If it does not work, it may be a photo program like Kodak or Adobe Pjotoshop that may be conflicting with the HP software.
Let me if it works or if not, do you have any of these programs installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 20, 2008 | HP Photosmart C6280 Printer
I am using a HP 2610 all in one printer on Windows XP and continue to get the following message at startup: HP Digital Imaging Monitor {CUE} has encountered a problem and needs to close. AppName:...
ok..my recommend
remove all software with add/remove program
go to www.hp.com and get fresh set of complete drivers for your model by operating system
re install
try it again
Aug 20, 2008 | HP Office Equipment & Supplies
Can't scan from printer or computer
Close the Digital Imaging Monitor.
◄ Start or restart the services :
1. HP Cue Device Discovery.
2. HP Net Device Discovery.
3. HPQCS08.
◄ Run Digital Imaging Monitor.
◄ Wait for a Minute, if the configuration screen appears it is done else refresh the HP Cue Device Discovery
◄ Restart the Printer
◄ 99% chances of resolution and in the other cases a proper uninstall and reinstall is needed
If the issue still remains then :;
Added the files to the firewall exception list
C:\program files\HP\digital imaging\bin\hpiscnapp.exe (version 10 software )
•C:\program files\HP\digital imaging\bin\hpqscnvw.exe (other than version 10 software
•C:\program files\HP\digital imaging\bin\hpqste08.exe
•C:\windows\system32\hpzipm12.exe
•C:\windows\system32\hpzinw12.exe
•C:\program files\HP\digital imaging\bin\hpqtra08.exe
•C:\program files\HP\digital imaging\bin\hpqthb08.exe
i. 68: dhcp client
ii. 80: web server
iii. 137:UDP Port 137 netbios-ns (UDP)
iv. 139: netbios-Session (TCP),
v. 161: snmp. (UDP)
vi. 427: srvloc. (UDP)
vii. 5353: mDNS
viii. 9100: pcl/pjl print.
ix. 9101: debugging tcp recv/send
x. 9102: debugging tcp send
xi. 9103: debugging udp recv/send
xii. 9110: echo
xiii. 9220: generic gateway (scanning, pml).
xiv. 9290: scan.
xv. 9280: generic gateway
xvi. 2500: scan.
May 25, 2008 | HP Photosmart C6180 All-In-One InkJet...
How do I check ink level in my HP Photosmart C4200 printer?
If your HP is installed you have "HP digital imaging monitor" on your toolbar.
1. right click, you will see "HP Photosmart..." - "Display status"
2. Click "View Ink Levels"
May 08, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
89 people viewed this question
jasbo
jasbo
