Question about Kenmore 98702 Stacked Washer/Dryer
Timer is not moving to next station won't go to agatation cycle
  • 443 Answers
Control timer has failed, a common failure in older washing machines, is not a difficult task to replace, if your handy with basic handtools you can complete this task on your own.
Take the brand,model,and serial number down to your local appliance parts shop and they will be able to assist you in getting the correct replacement control timer.
GOOD LUCK !
Posted on Aug 20, 2010
Will not move to next station
Is this a sprinkler timer?
Copy following link to access manuals for each brand sprinkler timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and describe product in detail, including model, brand, and approximate age.
Gene
Aug 09, 2013 | Hardware & Accessories
Timer programming help
Maybe the sprinkler head is not advancing.
May 22, 2013 | Orbit Hardware & Accessories
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Wont do the spinn cycle
use pencil or something to push the lid switch farther down if it works then replace lid switch if not...check timer
Aug 10, 2009 | Washing Machines
Washer will not go onto next cycle
Timer control is bad needs replaced
85 -100 dollars
Jun 02, 2009 | Washing Machines
Maytag washer noise during wash cycle
Check for the tighten nut to agatator is tighten. If agatator is lose it floats up and down during the wash. There is a lock ring (rubber) on the shaft that holds the agatator on, check this, if off replace thid . If the agatator is still in good shape can still use it , if not pull of and replace it. This work is't hard to do.
Jun 01, 2009 | Maytag Legacy Series Top Load Washer
TIMER ON WASHER MAKES A TICKING SOUND DURING CYCLE
HI, this timer is faulty and, these are early warning signs of potential failuer of this device in the near future. i would prepare to replace the timer control soon. the actual mechanism is showing signs of breakdown.
May 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Maytag washer will fill but never starts cycle
motor is faulty most probably
or mayby faulty capacitor on motor
Mar 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
Washer go though all cycles but no spin
the motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Aug 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
61 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
