Question about Samsung Cameras
ES55 won,t turn on, can get menu up. Beeps when power button is pushed lens starts to come out but stops and then nothiing .SamsungES55
Check this links for stuck lens and follow the steps on how to fix it. Good luck.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Sep 12, 2010
Forgotten how to turn it on. It seems to be set on timer. Oops
push stop button for a few seconds until it beeps or the readout changes. unplug,,,,,plug back in....push "Select" or "menu" button depending on which machine you have....push again and again until the program you want is on the display or readout. Then push the "start" button ....Don't push any timer buttons or arrows!
Dec 04, 2011 | Kitchen Appliances - Others
My ps3 will not show i have a disk in the console. I tried cleaning the lens still no disk. Help?
The problem is that the lens of your ps3 is either dirty or weak that it can no longer read any disc, i advice that you get a lens cleaner to clean the lens of your game, if after cleaning, problem persist, replace the lens on your ps3 so that your ps3 can continue to function as it use to function before.
Replace the lens on your ps3 and you will see that it will start reading discs.
You can also try the below procedure before replacing the lens,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 13, 2010 | Sony Playstation 3 (PS3) Console
Do not read the disc
You can also try the below procedure,
Take care.
Jul 21, 2010 | Sony Playstation 3 (PS3) Console
When it starts it beeps 3 times and then shuts down
It sounds like it might have overheated, first let it cool down for a little while then and try again. If it starts working again, get compressed air and clean out the PS3, and possibly get an external fan to stop so this doesn't happen again. If the PS3 still does the 3 beeps try putting the PS3 in recovery mode by going to the recovery menu. Which can be done by doing the following.
  • Turn off the PS3
  • Hold the power button down; the system should turn on and turn itself off.
  • Once its turned it self back off press the power button intill you hear to beeps
  • After you hear the beeps let go of the power button
  • You will told to plug your controller in and press the PS button
  • Then the recovery menu will pop up
If the PS3 still doesn't turn on it be dead and need to be replaced. Best of luck!
Jul 18, 2010 | Sony Video Game Consoles & Games
Es55 camera turned it self off ith the lens out.no when you turn it on littlegreen light comes on then camera beeps and goes off after about 2 seconds
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may be time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 06, 2010 | Cameras
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
PS3 yellow light and then turn red
Have you tried accessing the PS3's recovery mode?
How to Access Playstation Recovery Menu
2. Hold The power button down; The system will turn on and turn off once again.
5. You will be promted to plug in your controller via usb and then hit the PS button
  • Lastly You could try a full system restore WHICH WILL ERASE ALL YOUR HDD ITEMS so back them up if you wish
  • ****UPDATE***** You could also insert a Blu ray Lens cleaner disc into the disc drive and it will clean the PS3 lens either as a preventitive, or after the fact the drive stopped reading your discs because some people have reported their system reading discs again after this process.
  • You could always lastly take apart your system and try cleaning the lens with cotton swab and alcohol as a last effort scenario especially if your system is already out of warranty
There's now a technician on E-Bay who fixes this damn yellow light of death for out of warranty owners for $75.00 Just seach for Playstation 3 repair service on E-Bay
Mar 04, 2009 | Sony PlayStation Video Game Consoles &...
Samsung S1065 does not turn on, beeps 3 times before powering off. Lens is extended, have checked batteries, not sure what else to do??
I had the same problem, firstly you will be able to press the button on the back to view your pictures, when you do and the camera powers up quickly press the menu button. Check that your battery settings are set to alkaline, then buy some good alkaline batteries and not cheap ones. Check that they are alkaline and not like what I did and bought panasonic zinc carbon.
This worked for me and mine would not turn on either until i changed the batteries to a good make.
Oct 01, 2008 | Gateway DC-M40 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Cameras Logo
642 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
