It has dots on it. - Computers & Internet
  • mmetrick Aug 20, 2010
    My Mac Monitor has lots of dots on it. What can I do?
  • 11,800 Answers
What has dots in it?
Posted on Aug 20, 2010
  • Azrael SRL Aug 20, 2010
    In that case there can be 2 causes for that:
    1 - if the dots are the same whatever the image on the screen then the monitor's LCD panel is dying - this cannot be fixed, the monitor must be replaced.
    2 - if the dots change constantly all over the screen then the video card in your Mac is dying and must be replaced.
Need echo dot app with setup instructions
hi Gary.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
if this does not help you out go to this link and read up some more.
echo dot app with setup instructions Google Search
Nov 20, 2017 | Echo Computers & Internet
Setting up echo dot
hi roger.
see if this helps you out.
or if you need more help go to this link.
Setting up echo dot Google Search
Nov 16, 2017 | Echo Computers & Internet
Can I use DOT 4 brake fluid?
dot 4 brake fluid is suitable to top up all dot specified brake fluids
the dot fluids are glycol based fluids are are used widely in the transport industry
the are controlled standards issue by the department of transport (DOT) your car will not be using dot 5 fluid
the main differences between the dot standards is the boiling points of the fluids
for example dot 3 wet boiling point is 140c-284f
dot 4------------------------------------------155c-311f
dot5--------------------------------------------180c-356f
dot5.1------------------------------------------190c-374f
a brake fluid compatibility chart shows the following
dot 3 with dot 3, dot 4 NOT dot 5 , dot 5.1
dot 4 compatible with dot3 dot4 NOT dot5 , dot 5.1
dot 5 Not Compatible with dot3,dot4, dot5.1
dot5.1 compatible with dot 3,dot4 dot5.1 not compatible with dot5
refe to site epicbleedsolutions.com for references
for any other information as to why boiling points are the main factors and why brake fluid should be changed on a regular basis go google and type in ---brake fluid dot specifications and compatibility--- and there are many informative sites available
Jan 04, 2016 | 2000 Hyundai Elantra
4.3 timing marks on crank
It should be the old "dot to dot" method.
There should be a dot on both sprockets. The bottom, or crank sprocket, the dot should be straight up, or at the 12:00 position.
On the top sprocket or cam sprocket, the dot should be straight down, or the 6:00 position.
hence the "dots will be facing each other, or "dot to dot".
Hope this helps.
Feb 23, 2015 | Chevrolet Blazer Cars & Trucks
Is timing set dot to dot on 1954 , 6-cylinder engine
what motor are you working on? lots of chevy 6's out there.
Dec 31, 2014 | Team International Rien's Stock Car...
Can a nissan primera 2005 use dot 3 and dot 4 brake fluid
The standard brake fluid for your car is dot 3. This is the best for your car. Dot 4 is a higher standard brake fluid for newer car makes. I don't see any advantages of dot 4 your 2005' car. Other fact is dot 4 is more expensive than dot 3.
Regards
Aug 23, 2011 | 2005 Nissan Altima
What type of brake fluid goes in a 2000 chevrolet silverado
The filler cap and manual both specify DOT 3--"Delco Supreme 11" or equivalent.
Lets look at what the DOT ratings mean. The table below shows the MINIMUM wet and dry boiling points for DOT 2, 3, 4, and 5 brake fluid in degrees fahrenheit.
DOT 2 DOT 3 DOT 4 DOT 5
Dry Boiling point 374 401 446 500
Wet boiling point 284 311 356
The DOT 2 spec is for drum brakes and is obsolete. If you have any DOT 2 in your garage, throw it away!
DOT 5 is for silicone brake fluid. Silicone brake fluid (DOT 5) should be avoided because it is not compatible with regular brake fluid, it is hard to pour without introducing bubbles and thus results in soft pedal feel, and moisture still gets into your system and will pool in low areas like your calipers and encourage rapid corrosion. STAY AWAY!
That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with each other and may be interchanged or mixed with no ill effects.
I haven't had any problems at that time adding Prestone DOT 4 to the original GM fluid.
Changing BRAKE FLUID is a MUST. Most dealers recomend at 60K scheduled maintenance service.
The industry standard is every 3 to 4 years for DOT 3 and every 2 years for DOT 4 under normal driving conditions.
Nov 08, 2010 | 2000 Chevrolet Silverado 1500
The mil dot - dots do not agree with what they should be according to the detailed info that BSA sent me , nor does it agree with what i have read on the internet about mil-dot ranging.
the mil dot settings are only a guide there not the rule, its all down to what rifle your using and what bullet your fireing the only way to check the mill dot ranging is to test fire at targets till you get the feel of the scope after all if your using a .22 rim fire and get the mil dot ranges then change the rifle to a 308 the mil dot will be well out, i have mil dot scopes but never use the mil dot i gess the hold over/hold under but then i have been shooting for over 50 years now
Jan 13, 2010 | Optics
Transfering Macros, changing normal.dot files
Try to save the normal.dot file in my documents and then open with word, then close word and it should tell you that normal.dot has changed and ask if you would like to save it. Select yes.
Apr 29, 2009 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
David Payne
David Payne
