Question about Samsung Washing Machines
I got a EA or ER error code on my Samsung B1113j washer. It was during the spin cycle. I tried to rerun the cycle but the washer would not spin and was making alot of clunking noises. Is this an easy fix, perhaps something simply came loose. Please help, I just bought this place and the washer came with it and I don't have much money at this time.
  • 4 Answers
SOURCE: Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Posted on Jul 08, 2007
SOURCE: Samsung B1113J "error code EA"
A Tech I called said auto sensor was the tach on the motor.
Check for proper resistance across pins 3&4 at the motor plug (2 red wires). Should be 150 ohms.
If proper resistance, could check connections at board and board itself.
Though I wonder what the error would be if the motor wasn't turning and this looked like an error with the tach. Would this this be an EA error too?
Posted on Apr 09, 2008
Lumpy816
  • 246 Answers
SOURCE: ensignia maytag washer noise
The bearings on Maytag Ensignia's are part of the seals that keep the water in. Once you start hearing the bearings begining to go, you likely will have a leak following shortly thereafter as the bearing greased is washed out by your laundry soap. Up front. This is a procedure that requires specialty tools and takes me about 45-60 minutes to complete. The easiest way to tackel this job is to take your model number (just on the back side of the console) and take it to a local appliance parts store. Ask them for a tub seal kit. (I can't give you a part number since there is no model number listed) but they should be able to pull it up for you. When they bring it up to the front, inside the seal kit is not only step-by-step directions, but also the part numbers for the specialized tools required as well. If you opt to go the repairman route, I'll forewarn you, the company I worked for charged around 250-300 for the repair on this. Send me back a message if you have any troubles or other questions.
Posted on Jul 01, 2008
duby1990
  • 370 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
SOURCE: Clunking noise and vibration during final spin cycle
For all those who say they recently bought the machine, the cause of the machine "walking across the floor" and vibrating violently is the packaging bolts on the back of the machine that were supposed to be removed when the machine was installed (why it says remove packaging bolts in the installation manual). These packaging bolts hold the suspension steady and firm during shipping but MUST be removed before operating the machine. When these packaging bolts (I think there are four total, some up to 6 inches long penetrate the rear of the machine) are removed, they allow the suspesion to absorb the vibration.
Posted on May 25, 2009
My Samsung B1113j washer stops at the rinse/Spin cycle. Does nothing just stops?
Check input power supply and pre fuse it may possible to broken . if its then need to replace the pre fuse .and then try again
Aug 07, 2016 | Samsung Washing Machines
Washing machine EWT704S keeps displaying error code EA.
Found this
Re: Samsung B1113J "error code EA" A Tech I called said auto sensor was the tach on the motor.
Jan 06, 2016 | Washing Machines
I have a top load samsung washer and for a while now it will give me a dc error code and won't spin all the water out of the clothes? Need help thank you
If your Samsung top loader is starting to spin, but stops after a minute or two, and starts to fill up with water again... and then after 3 times of doing this, it errors out with a DC error code, the problem could very well be with the support rods. The springs in these rods will get weak over time and allow the drum to become unbalanced during the spin cycle. Fortunately, the 4 support rods are very easy to take out and replace. And sometimes, they just need to be greased properly. I had a service technician replace my support rods, but he didn't grease the top and bottom bushings first, so my machine still wouldn't spin properly. After he left, I pull one of the support rods out, cleaned out the dried up grease where the support rods lock in, and applied a liberal amount of white lithium grease to the top and bottom bushings on the support rod. I then put it back in. I did the same for the 3 remaining support rods. Now the support rods were able to move very freely in their holders, which is necessary during the spin cycle. My machine now spins like it is supposed to and I don't get the re-fills and DC error code anymore. This webpage, http://www.appliancepartspros.com/samsung-assy-damper-owm-dc97-16350c-ap5623264.html , contains a video that shows you how to remove, inspect and grease your support rods properly. It is not hard to do, but can be a bit messy. Have gloves and/or cleaning rags handy. And if you do need new support rods, this place has them cheaper than you can get them from Samsung!!!!
Dec 14, 2015 | Samsung Washing Machines
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
I have error 6E on my samsung washer
If during the spin cycle, the error code could be an error with the printed circuit board assembly of the washer. This means that the temperature readings are incorrect and the error will continue to display.
E6 error code indicates that the water heater is heating water too fast. Press the power button once to clear the error and finish the cycle before repair.
Check this link with additional info: original/457.jpg?1285349415
Hope this helps.
Apr 18, 2011 | Washing Machines
Whirlpool calypso washer stops during cycle and then tries to start up over and over again. The unit will not finish the cycle. I have been able to unplug the washer and rerun the cycle, but it is...
The problem possibly might be the motor brushes.Take back panel off and disconnect the motor. Remove the bolts while holding the motor in and take out motor. Finally check for the condition of brushes. It would have gone bad
Mar 29, 2010 | Whirlpool Washing Machines
Please help! My samsung 7kg J845 front loader keeps flashing UE on the error code (spin cycle) and I can't open the door. Sarah
Hi, I have the same washing machine and it flashes UE on the error code during spin cycle when I have one thing in there, or if the clothes are uneven. I usually have to wait until the lock light goes out, re-arrange the clothes and continue spin cycle. If it is just one item in there, I usually have to manually wring it out as it will keep saying error if I keep trying to spin.
Oct 22, 2009 | Samsung WF337AA Front Load Washer
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
Oct 27, 2017 | LG WM1814CW Front Load Washer
Mar 21, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
257 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
